25W Single Ended Hammond 193V Choke Loaded 2SK180 L'Amp
Quick response thank you, the sound of your mounts with Sit is very good (I also tried in ra7’s TDV montage follower with Front end 2022), the sound is beautiful in both cases.
I’m in the stage of making the box, the most difficult!
Another big “thank you” for your support.
Reactions: Ben Mah
I'm looking at chassis ideas for this build. Modushop has a nice pair of monoblocks that might fit the bill.
https://modushop.biz/site/index.php?route=product/category&path=324
The chassis is 6.25" high internally, although appears to have decent ventilation. The perforated bottom panel eats about an inch of internal space, but the largest part seems to be the Antek AS-3430 at 5", so it would fit if upright. Internal space is otherwise 230mm x 400mm (9" x 15.75".)
The heatsinks are two (per chassis) 200mm W x 165mm H x 40mm thick, so in total 400mm x 165mm per chassis.
If the 2SK180 were mounted centered between the two heatsinks, would it be enough cooling?
Thanks.
Reactions: Gianluca
Looking at the specifications on the Modushop website, each 200mm x 165mm heat sink has a C/W of 0.38, so for two the C/W is 0.19.
For comparison my amplifier build has a Modushop 300mm x 200mm heat sink with a C/W of 0.20. The heat sink gets hot but still cool enough that I can keep my hand on it indefinitely. No doubt the large aluminum chassis helps to dissipate some heat too. However I think the Modushop monoblock chassis should provide adequate dissipation.
Yes the 2SK180 should be mounted centred between the two heat sinks. Because of the physical layout and pin location of the 2SK180 you will need an aluminum angle or tee to mount the 2SK180 and that will help to distribute the heat to the two heat sinks.
Reactions: bhjazz and Gianluca
Thank you, Ben and Gianluca. Also, I'll add a category to Nelson's heat calibration chart: Not hot, which would be somewhere below Blimey hot on this chart, and seems to describe "...I can keep my hand on it indefinitely":
I'm going to have to put this on a T-shirt at some point.
Which pcb company did you try?
I just checked on the JLCPCB website and the price for the amplifier pcb was $7.00 plus $1.50 for the slowest shipping. The price for the power supply board was $6.80 plus $1.50 for the slowest shipping.
These quotes were for two separate orders and shipments. The total price may be higher if the two boards are ordered and shipped together.
Reactions: Monk55
I'm working on another order for parts for my build and figured it might be best to check in with the group so that I'm not ordering parts I can't use. I will be building this design for a pair of 2SK180s. I have taken the parts list from what adrianrw posted a bit ago, but since he was building for the THF-51S I want to make sure the parts do not change for the 2SK180.
A few questions:
For the power supply parts:
I only found a part number for one of the bridge rectifiers, the 1000V 35A version, part # 4878-KBPC3510FP-ND. Are both rectifiers the same? I can't seem to find a reference. (Additionally, the schematic shows the part values as 600V 35A.)
General parts not on schematic:
CL60 thermistor for transformer primary windings (to work as soft start.) Specs or part number available?
Barrier terminal blocks - these are probably fairly general, but if there were a part number, I would really appreciate it.
Finally, here is the parts list.
AMPLIFIER BOARD PARTS
Antek AS-3430 (dual 30VAC secondaries, 300VA)T1AS-3430
Hammond 193V (150mh,@3A DC) (DC filter choke for amp board)L1HM1567-ND
Hammond 159ZJ (used to power CLC filter) (choke on power supply board)T2546-159ZJ
CAP ALUM 1000UF 20% 25V RADIALC1493-10989-1-ND
MKP 4F 10% 350VAC PITCH 27,5 C2, C52870-MKP1847C540355K2-ND
CAP ALUM 33UF 20% 25V RADIALC3493-15435-ND
CAP ALUM 47UF 20% 25V RADIALC4493-3179-ND
CAP ALUM 10000UF 20% 50V SNAPC6493-13364-ND
CAP ALUM 1000UF 20% 50V SNAPC7493-16228-ND
CAP ALUM 470UF 20% 63V RADIALC8493-11032-1-ND
DIODE GEN PURP 100V 1A DO41D1,D21N4002DICT-ND
PTZ18B: DIODE ZENER 18V 500MW DO35D3TZX18B-TAP
Yellow 585nm LED Indication - Discrete 5V RadialD4516-1341-ND
RES 240 OHM 1/4W 1% AXIALR1RN60D2400FB14
RES 2.0K OHM 1/4W 0.1% AXIALR2CMF502K0000BEEB
RES 10.0K OHM 1/4W 1% AXIALR3CMF5010K000FHEB
RES 47K OHM 1/4W 1% AXIALR4RN60D4702FRE6
RES 34.8K OHM 1/2W 1% AXIALR5CMF5534K800FHEB
RES 1.50K OHM 1/4W 1% AXIALR6CMF501K5000FHEB
RES 5K OHM 1/4W 1% AXIALR7, R8RN60D5001FB14
RES 220 OHM 3W .1% AXIALR9RN60C2200BB14
RES 22 OHM 1/4W 1% AXIALR10RN60C22R0FB14
TRIMMER 20K OHM 0.5W PC PIN TOPRV1T93YA203KT20
Linear Voltage Regulator IC Positive Adjustable 1 Output 1.5A TO-220-3U1LM317HVT/NOPB-ND
POWER SUPPLY PARTS
CAP ALUM 22000UF 20% 50V SNAPC1,C2,C3,C4338-1599-ND
CAP CER 10000PF 1KV Z5U RADIALC51255PH-ND
CAP CER 0.015UF 1KV Z5U RADIALC6562R5GAS15-ND
BRIDGE RECT 1000V 35ABridge Rectifier4878-KBPC3510FP-ND
Bridge Rectifier for the 15VAC secondary winding on the Antek transformer.Bridge Rectifier?
FIXED IND 10MH 5A 160 MOHM CHASS (59ZJ transformer)L1HM1555-ND
RES 4.0K OHM 3W 1% WW AXIALR1RSB-4.0KRCT-ND
RES 40K OHM 0.1% 1/4W AXIALR2273-MOX70034002BYE-ND
RES 33 OHM 3W 1% WW AXIALR3RSB-33CT-ND
LED RED DIFFUSED T-1 3/4 T/HD5160-1969-ND
Also highly recommended is a CL60 thermistor for each transformer primary winding to work as a soft start.
Barrier terminal blocks - 3 per amp
https://www.mouser.com/c/connectors/terminal-blocks/?m=Eaton&number of positions=6 Position
Switch, fuse holder, RCA jacks, binding posts, L brackets for 2SK180, wire, nylon should washers, time, a clear head, etc.
Am I on? Am I way off? Either way, thanks for the help!
i will try to build one these THF51S Follower in the following month , it seems to be difficult to build a stereo amp with both the linear power supply and the big 193V choke i have . so is there any external SMPS to use ? is one 24V 5A meenwhell per rail will be ok ? running at 2.6A ?
A big Meanwell on the positive side (that is: 5A or 6A quoted is what I have). This terminated in earth.
The second one that supplies the V- can just be 1Amp, as that is just signal. Minus 15V is also OK, as this side is a CCS. This means that well, you save money.
As for precut insulating pads, there are some on ebay.
I do not know if there are any precuts available from Mouser or Digikey.
I usually buy rectangular pads from Mouser, although now I will only deal with Digikey as they ship from Winnipeg whereas Mouser ships from Texas. Plus recently shipments from Mouser have been delayed for days due to export control holdups.
