I see it at DS6 cathode (I misread your post and read DS6 but it happened to be there)
Not at DS2 or DS4
Might be a hint of it at DS7 but may just be other noise
Not at DS2 or DS4
For RS35, do you see more of the noise on the DS6 end of the resistor or on the protect LED end of the resistor?
For RS30, do you see more of the noise on the DS6 end of the resistor or on the other end of the resistor?
I see the noise on both sides of RS35
I see the noise on the side of RS30 closest to the top of the board
Closest to the top of the board doesn't tell me anything. Is that terminal of RS30 directly connected to DS6?
That seems like you have a bad ground reference. Using the scope probe's short ground lead, connect it to pin 7 of the PS driver IC (solder a short, small wire to that pin or a close circuit point to clip to) and re-check for noise on all these points (and previous points). Set the scope to 0.2v/div.
Ground to pin 7 of US1. Either to the terminal directly or to a very close point in the circuit if there is an easier point to connect.
I pulled the good amp I have (different model than the one in this thread) out of my car to properly set the gains. The scope was messed up and giving weird readings (scope ground directly connected to amp ground), and my amp started making a high pitched sound from the amp itself.
Disconnected the amp, connected it back to the car and 2 restarts the sound went away.
I think somethings up with my lab, either cursed, something isn't working right and throwing everything off, or I'm probably doing something wrong.
As for previous post, any other possible places (if it's not my scope settings being incorrect)? I'm not too confident soldering to a pin like that with it being obscured by other components on the board.
While not as good, you can ground to the ground terminal of the driver board (where the two added caps ground). Use as short a wire as you can.
- General Interest
- Car Audio
- 2 Monoblock Class Ds Not Working, I'm Lost
