1400 uf 350 VDC computer grade electrolytic
i had a client about 8 years ago asked me to build him a 6H23 ccda line amp....he specifically wanted as many caps i can put into a router casing.....who am i to tell him he is nuts????? 😀
Ok how can I use 1400 uf 350 VDC computer grade electrolytic capacitor(s) in a tube amp power supply. The company my son works for installs server farms and they have a case of NOS never used 1400 uf 350 VDC computer power supply capacitors heading for the dumpster. I told him to grab it for me. I was thinking as part of a brute force power supply for a preamp or amp running on under 300 volts. They are Sprague capacitors so not Chinese crap.
actually big caps and tube power traffo can go together well, why? because the impedance of tube power traffos are such that charging currents are not that extreme....but if you choose to go this way, then tube rectifiers are out of the equation....
the VTL 6L6gc pp amps used 1000ufd/300vdc in series....other stateside manufacturers are doing it...
but of course, if you do not understand the implications and the hazards that goes with big caps, then do not do it....simple as that...
My "super picky" audiophile friend, from a group of Vietnamese "audio nuts" got his Harman Kardon Citation II back the other day.
On another thread, I discussed having to overhaul the amp..
Mind you, it is now powered by an almost stock B+ supply, which I "upped" to 90uF (multi-can of 3x30uF) from the original 40uF.
The bias supply is "upped" to a pair of 100uF, from a pair of 20uF.
No biggie capacitors like 1000uF's involved there..... no obsessive banks of cans like I see in these photos.....
The amp's KT88's run on the "cool side" and only a barely audible-if-you-put-your-ear-against-the-speaker hiss.
His,and his friends, reply to me at a group listening session today..... "simply beautiful!..fantastic job!"
By the way, the speakers used in their "test" were a pair of Altec Lansing Valencia's.
I have to admit I have a pair of 9100 uf 250 volt caps in series for my 845 amp. It has a 1,5 H choke between the 1n4007 rectifiers and the cap. It has been my generic tube amp power supply for quite a few years. The high capacitance is probably not necessary but they were free from a retired UPS.
I was under the impression that 1000u was needed per 1A of current for PSU's, so for a 120w that draws 0.6A at full power I used that much capacitance. An amp sounds better with a hefty PSU on the transients, I'd love access to a box full of these.
Also where they come into their own is when used with high HT ; two or three in a 6/700v PSU or even 10 in series for a 3.5kv sounds about right. Therefore these are very nifty caps to have.
i am very sure that if the designers of old were alive today, they would be jumping up and down with joy with today's available e-cap quality and quantity...and with a good price to boot...😎
Reactions: gorgon53
Add a power stage and they will be more useful though...
Here's what I use for my monoblocs, but as other have stated, the capacitor is overkill for a preamp.
If you power up old caps in an amp build using a light bulb limiter or variac for the first time you *are* re-forming them. Just mot necessarily in a controlled manner. If they don’t form they’ll heat up quickly and die. You might have been lucky and not had one *die* in a spectacular manner.
The more in need of reforming they are, the slower you have to do it in order to be successful. Also the bigger bang that it could potentially cause, the slower you *should* do it.
I can’t see throwing perfectly useable amplifier capacitors in the trash, even when I have more than enough money to buy a brand new one from Mouser. That won’t always be the case.
If you saw my parts sash you’d say I was crazy. I’m retiring in a year, perhaps two, and then the days of spending big bucks on electronics will be over - for good. The idea is to have enough inventory to keep working on this stuff for decades, with a reasonable budget for shop supplies (resistors/caps, wire, solder, hardware, etc). I have many many many unused computer grade caps, most purchased surplus, that were formed and stored in air conditioning. I’m counting on being able to use these, rather than spend $27 on one or two from Mouser on every project.
