10F/8424 & RS225-8 FAST / WAW Ref Monitor
Pictures would be helpful
Does this illustration help?
The poly-fill stops a little behind the driver, so that the cone has a little breathing space, and the poly-fill doesn't get into the driver basket assembly. The felt lining material is fixed to the insides of the walls of the cone (or similar structure).
Reactions: kking85743
These are for a DIYA member in Hawaii, not Walter.🤣
They get packed with EPS foam panels and hard cardboard reinforced corners. Then wrapped in corrugated cardboard box. I’ll see if we can get more photos of how they are packed. I know it takes about 30min to unpack them. FedEx freight is usually how they travel.
It will be fine. You are on the edge of E(xtended) B(***) T(uning), which gives a shelving(droop, but fairly flat) in the lower bass.
You can diminish this by using an air-core coil in your lowpass(the small extra resistance will raise Qt slightly).
Or, and I like this, you can use a huge port, which will reduce internal volume a bit, and "chuffing?! We ain't got no steenkin' chuffing!!"
I have had the 225-8 be very happy in 44l, just be prepared to try a few tunings to find what's best in situ.
2cu ft ported could work - I think Aatto had a rather large ported box earlier in this thread but he might have been using an SB29. Just work out your tuning. The nice thing with the TL is that it gets cone control and deep bass extension. 2 cu ft sealed might be pretty good too - easy to check by plugging up the port.
I agree, transmission line should limit excursion all the way down, but for me, that's a big box to mail.
if the 1.2ohm wasn't there (the inductor's resistance), I get.......................
.707 sealed
vb= .81 ft3
f3=fsb=52.6
ported
Vb=1.64 ft3
F3=31
Tune= 30
So, qts gets a squeek higher with the resistor. Using
http://www.mh-audio.nl/Calculators/newqts.html
assuming re=8, I punch in 0 ohms, qts ends up at .38
but add 1.2 ohms resistance (inductor), qts is now 4.2
.707 floats up to 1ft3 for f3=fsb=50hz (basically the same)
while 4th goes to 2.2ft3 with f3 and tune below 30hz
so, 2ft3 tuned to 30hz should work fine.
