100W Ultimate Fidelity Amplifier
Q7 Q8 are 2SA1943 Q15 Q16 are 2SC5200. Are there any errors? 34 — ImgBB
Can anyone suggest a good Diamond Buffer (with or without onboard volume pot) where the gerbers or perhaps even the Eagle or KiCad or pcbCAD720 files are available and sharable?
I would like to order from jlcpcb.com and make a good Diamond Buffer to put after my volume potentiometers for my DIY amplifiers which have sufficient gain to not require a pre-amplifier. So far I have been experimenting with breadboard based 2SC2240/2SA970 and KTC1845/KSA992 Diamond Buffers.
Yuriy64
Юрий, хотя тут принято писать на английском, зачем дважды делать перевод. Есть два варианта питания до 45V и от 50-75V. Во всех диапазонах он работает. У меня лично работает +-75V на 8Ом. Питание Тор. На один канал один стабилизатор. (PSU) 2х20000Uf в плечо. Хотя он отлично и без них работает.
___________________________________________
:cop: This is an English language forum, You must post in English. Posting in any other language is not allowed unless you provide a complete translation into English. This is made clear in the RULES.
Yuriy64
Fix our mistake.
Yuri, although it is customary to write in English, why do the translation twice. There are two options for eating up to 45V and from 50-75V. It works in all ranges. I personally work + -75V on 8Ohm. Eating Thor. One stabilizer per one channel. (PSU) 2x20000Uf into the shoulder. Although he works well without them.
Hello, APEXAUDIO. Thanks for the good decision. SR200! True, the size of the standard fee was small for us. We have developed another version of the PCB. Your fee. They worked everything first on the simulator. Assembled and launched. For a year he has been working without complaints. Everything is great!
apexaudio SR200 users
SR200. There's a little nuance to this decision. Diodes D3 and D4 it is better to close in heat shrinkage from light ingress. Standing at the entrance LF411. Stability is increased. Otherwise, sometimes floats zero at the exit. And it's worth it iron. Checked on 8 collected different boards.
All fet buffer
Before I turn on this (FH9 based board) can anyone post pictures (front and back) of genuine Siliconix/Vishay IRFP240, IRFP9240? (And ST BD139/BD140?) Or compare my photos with your known real devices from authorized distributors.
I have attached photos of what came with the boards. I am hoping to determine if they are "genuine"/safe before turning it on.
I was also planning to initially test at a low voltage. Would it be a good idea or bad idea to initially turn it on with +/-15V from LM317/LM337 board? I ask since I have run into too many "weak" (fake) power transistors.
If you think they are iffy I will take a slower route and get genuine outputs and drivers from Mouser or Digikey.
The Mosfets look real (match my Vishay's from Mouser) and I don't have ST BD139, mine are ON Semi from Mouser. Posted pics of the one's I had on hand.
Only the BD139/140 backs look different, the ON Semi's I have are square corners (I checked the 100 (4 different orders) I have and all the same square corners for BD139 and BD140)
I don't think BD139/140 are so expensive to need fakes, but use a DBT to bring it up and you should be able to tell very quickly if the bias or offset is unstable.
I have built 6 FH11 (same design with 2-pair of outputs) and the bias is rock-solid from start-up to hours of listening.
Thank you for the reply and the photos!
Thank you also for the comment on the FH11 amplifier. When I prepare the heatsink I will leave space and drill extra holes on either side for an extra IFRP240 and IRFP9240 pair. That way I can easily later add the second pair with 220 Ohm and 0.22 Ohm resistors soldered to the leads of the extra pair.
My speakers are sold as "8 Ohms" but when I measured them with REW then are clearly 4 Ohms. So I prefer two pairs of outputs.
