100W Ultimate Fidelity Amplifier
FH9/FH11 adapted to each other (I)
Most of the parts are the same for these 2 amps. So the idea was, to choose same part designators (R1, C1, etc) to same parts in layout as well as in the schematics and the BoMs.
Here are now the Gerbers and the BOM (V1.0.7) for FH11
  • GerberFH11V107.zip
    GerberFH11V107.zip
  • FH11 BOM Rev 1.0.7en.zip
Hello apex sir
http://www.diyaudio.com/forums/atta...4-100w-ultimate-fidelity-amplifier-ax11-2.jpg
How to start testing this AX-11(post #1980) before attach to speaker.Please can you give step by step instruction.
Like all amps here, use either a light bulb mains tester or 10R safety power resistors between the PSU and amp on each rail. Ground the inputs. Use DMM to monitor current on safety resistor. Observe voltage when applying power for first time. If more than 10v (more than 1amp across resistor) immediately disconnect power and debug. If less, circa 2-3v adjust bias trimpot to desired level. Then check DC offset. If all looks good, disconnect power, remove safety resistors, connect speakers, connect audio input to source and enjoy your amp.
Hello Xrk971
Thanks for replay.But how to ground the input meaning is it I have to attach input ground to power ground and stay open input signal.what is offset volt to set.how much volt I have to set acros 10R resister.
As suggested track, also PCB size was now reduced to 60X70mm.
Sure...
Hello wiljj78
What is replacement of transistor BD249c/250c.and other transistor in my area it is hard to find BD249/250.Can i use 2sc5200/2sa1943 and can you suggest any BC replacment for mpsa92/13. What other changes i have to make in circuit. I have 35+/- supply.please help.
Eaglemaster,
Thanks for the nice layout. I really want to build this but my to-build list is already too long. Looks nice though to give flexibility in design and great mod of Sonal's excellent starting layout.
It's such a beautiful board I may order some just to have for a rainy day. 🙂
Many thanks, xrk971.
Though I spent a lot of time I conciously tried to keep the changes in the design of the amp and the PCB as low as possible for some good reasons. My experience in amps is far away from yours and my experience in PCB design for amps is even farer away from Sonal's.
Nevertheless I wanted to be able to built both amps on the same PCB (I ordered in the meantime). My space I have for the PCB allows 100mm, so this is no restriction for me! Only for those who have similar intentions and low restriction too, I published the results!
FH11 V1.07 Some more information on the silk screen!
Hi Eaglemaster,
Very beautiful layout indeed. If I understand correctly, the idea is to use same PCB for both amps? In that case, would it be possible to mark additional components for second amp with a dot mark?
reg
Prasi
A great idea, Prasi!
I marked those parts which can be omitted for FH9 with a full dot and those parts, which have different values with a ring.
Find attached the changed silk screen Gerber file.
Thanks for updating that Eaglemaster. Are we pretty satisfied that this layout is now error free? I want to order some boards. I think this is perhaps one of the most useful amps as it can be configured as either single or double outputs. Sounds great. Easy to build. Sinple to setup. Make one of these and give as gifts to friends and they will be amazed at the sound compared to most stuff they hear.
This amp is a perfect match for the $25 Abletec 53v SMPS.
http://m.ebay.com/itm/Abletec-900-W...fier-power-supply-53V-DC-UL-cUL-/251804683031
Every project needs a deadline (FH11/FH9)
Here are the values for the FR100 vbe multiplier. Works flawlessly.
The potential of good ideas on this forum is great! Nevertheless, I will do a cut now or I might still even contribute from the seniors home! :😀
I will again provide the complete set of files for the FH11 V1.07, this time including the dot marks for the silk screen AND provisions for a temperature compensated VBE multiplier stage.
The layout which I used as standard is at least 3 times build and that means measured/checked.
Nevertheless I added a diode; LED2, *hot-wired* (in series to VBE multiplier transistor) to give the possibility to test/implement the compensation for this layout.
So you have 4 different possibilities (with FH11 and FH9): 1 side or 2 side PCB, with compensation or original as proved and tested.
In case you ordered double-side PCBs, simply fit with the components printed on the top (silk screen) and you will get the proven and tested amp design.
In case you ordered double-side PCBs and you want to try the compensation with the LED do the same , but interrupt the track between the both pads of LED2 on the top. Then you can fit the LED and the changed resistors/trimmer.
In case you use a one-side PCB, fit all components according to the silk-screen/BoM and jumper the 2 pad of LED2. (Don't forget the jumpers for the 2 missing tracks on the top).
In case you use a one-side PCB and you want to try the compensation with the LED do the same, but leave the jumper and fit the LED2 and change resistors/trimmer. (Here again: Don't forget the jumpers for the 2 missing tracks on the top)
About reliability, xrk971, even if the scale do not fit completely: this layout is as error free as Windows 10 😉 but I checked it several times, so I hope really heavy errors can't be found any longer. But I would ask you to check at least BoM and schematic, if all used parts are ok.
