100W Ultimate Fidelity Amplifier
I knew there would be interest in a low cost Apex style DIY SMPS with 35 or 40v rails. What we need to do is add linear-style (shunt) regulation to the SMPS. Make it over voltage at say 40v - go through some CLC filters, and then shunt regulate with a MOSFET and zener stack or a TL431 and a driver... Sort of the best of both worlds?
Output voltage is not +/-50V... more about +/-30-40V... Use some transformer with about 60vac output and test smps, do not connect to main supply before 60vac test.
Shunt regulator for power amp PSU?
Good for cold winter nights....
Shunts are used all the time in high end class A amps. Isn't it the only way to get clean clean supplies? Anyhow I was thinking it just needs to burn off say 5 volts from 40 to 35.
Maybe RCLC 🙂
But if it all turns out to be such a hassle of expensive maybe just go back to the 10lb 250va toroid?
I am hoping the parts to the SMPS are like $10.
Maybe RCLC 🙂
I'm using 700W SMPS for big power amp.
The total cost was $150.00 for two of them, including shipping (from Jordan). Works great, smaller and cheaper than toroid + caps.
Guy that runs http://www.diysmps.com makes/sells them.
https://www.flickr.com/photos/danielminek/25994440043/in/album-72157667323114622/
I can't see a voltage doubler. They both look the same to me, except for that Mains AC link.
Does that link create a voltage doubler?
The FX8 Bimo - and I only have one so far so cannot listen to it in stereo, sounds very very good. It has the FX8 signature of excellent transparency combined with powerful bass authority. I need to build the second unit but I can say it is very similar to the FX8 50mm. I swapped one channel of the stereo FX8 50mm for the Bimo, and really could not tell the difference with my ear. I will wait for a stereo pair before a full assessment can be made.
This build was easy - this is a great PCB that is feature loaded: fuse holders, room for heat sinks in VAS, and large input capacitors of various sizes are accommodated. It's a very roomy board compared to the 50mm FX8 which is almost 4 times smaller.
