100W Ultimate Fidelity Amplifier
i made one more PCB .
Here drivers are BD139 and BD140 .
Lamp in primer on transformator glow high .
There is no trimer because i use potentiometer with wires .
All jumpers are there ....
sir take your time, the first time I power up my AX-14 I have a problem of a short from the screw holes it was touching the heat sink I just cleaned with a drill and all good to go 🙂
sir , i don`t have any screws in my PCB .
Now i take off all transistors . Every one from them is in perfect condition .....
And now i realy dont have idea what to do .....
This simple amplifier isn`t so simple 🙂
Hi, do you mean that it is normal at 20kHz and high amplitude?
With normal music and lower frequency square wave all is cool.
A 14V 20kHz sinewave is a heavy signal for a Zobel resistor.
A 20kHz squarewave sends out double the power (into a resistor) and all that extra power is @ or above 60kHz.
That results in a lot of heat. But it gets worse than that. The capacitor reactance gets lower as the harmonics rise and this results in more than double the power into the Zobel resistor.
Hi Andrew, thanks for the explanation.
regards Olaf
