100W Ultimate Fidelity Amplifier
Let me present my new headphone amplifier based on SR PP12 schematic , not tested yet ,but tomorow will be ......🙂
Regards,Alex
Ask For schematic
VAS from AX-14 can work with +/-120V DC rail voltage without change, with output stage upgrade U can get 500W/8R. I also use MOSFETs for some versions...
I made this class H version ' Ultimate 500' for test, and work great with +/-120V,+/-60V,0V rail votages.
Mr. Mile, can you share this Amp Schematic. AX14 with Stepper. It's very interested. Simple component & high voltage...!!
Apex AX14,chanel 2 almost ready, missing a few parts i'll buy them tomorrow.
What type of transistors can be used instead of 2sc5200/2sa1943.
Alex, nice work congratulations.
how to do a screen shot
[img=http://s21.postimg.org/84rw3qgnb/20150329_181446_1.jpg]
image sharing
I can't help noticing that your silk screen says BC547 and you have a BC546 there. Which one is wrong?
does not affect amp operation.
The BC5xx range are graded for different duties.
546 is the higher Vce version.
547 is the medium Vce
548 is the basic.
549 is the low noise version.
560 is the low noise and medium Vce version.
Add 10 for the PNP versions, 556, 559, 560
But they are all much the same.
