AX11/BG2_miniamp from borys
So i fire up AX11/BG2_miniamp today...Nice little board with good sound at all but not for hears...i explain : i has in my system a sound presentation that provide medium and upper frequency foward projection...and suited not to my hear, as i found some harshness and it produce hear tiredness....I has a good bass presentation...i try many bias level from 40 to 100mA and it's a little bette at this level but for me BG1_MJL as far my Nbip more accurate to my taste. Sound stage is better to as the sound can be pushed to high level with overall clean presentation. Monday i visit a friend. We will do listen session with our respectiv gears. I will relate you his comments on this amp.
Marc
Marc
I am having DC offset of +60mV at output of AX-20. Which resistor should I look for variance in value? Can trimpot be implemented to correct DC offset.
Marc
Nice work, what is speakers in your sound system?
I suggest to meatchin input pair for better offset, +/-20mV is ok.I am having DC offset of +60mV at output of AX-20. Which resistor should I look for variance in value? Can trimpot be implemented to correct DC offset.
PL14/XT25 combo : troelsgravesen VifaPL14WJ+XT25TG
Marc
Nice speakers, I want to try it in T Line or TQWT
I am not sure that the Tline will be important improvement...
Marc
Marc
I want bass under 50Hz
Hello Mile
Can I use this amplifier for project in my college
I want to know the specifications of this amplifier
could you please help me?
Thank you
Thank you
Test amplifier AX14P. Very good amplifier, a beautiful sound. +-50V, Uout-28V, R-4 Ohm.
Nice work.
thank you, apexaudio. Very good work at low frequencies. What are your THD? I have a THD 0.05% at 25 Watts.
This topology can have best THD 0,02%
sir mile, can i add this protect for other amp and having vcc 130vdc ?Test amplifier AX14P. Very good amplifier, a beautiful sound. +-50V, Uout-28V, R-4 Ohm.
and any change value for this protect can work for 130vdc?
No, use protect with separate psu.
Many expressed the odd harmonics above the steam?! I do not think it should be😕🙄THD, frequency response, the circuit board in SL 5.
cheers!
- 100W Ultimate Fidelity Amplifier
