24V D.C. protection.
thank's mr.mahailo...
Very nice pcb,
thanks apex
after the project is successful, I will be the apex layout B500tef v3
thanks apex
I sugest input stage from BX500.
includ input balance.
I also use it to B500. delay, dc protection, clip limiter and temperature protection works very well. BUT there is no protected LED, clip LED only. thkshi will j,
in this image where is the protect led?
regards
protector using IC555 with a few changes.
discard the clip limiter and plus speed fan control. works very well for almost 6 months.
regards
thanks for the reply,
which amp u used for this protect .?
can u share the layout of ur protect?
wattaniya,
I use a protector for BX500TEF.
I'm just an amateur designer, only used for hobby only. but it all worked out very well.
regards respect for mr. mile for all his contributions, I really appreciate it.
thks.
wattaniya,
thks.
Sir can you share the blue component guide in high resolution, sorry but its unreadable.
Thanks and regards,
wattaniya,
thks.
thanks for share &
what u use component in pcb protect :
1. RELAY type : ?? A =
vdc =
2. Transistor serial..????
3. Sensor fan...???
4. Sensor Protect ..
i can't post with high quality. limited size picture. maybe this picture can help you. regardsSir can you share the blue component guide in high resolution, sorry but its unreadable.
Thanks and regards,
thanks for share &
vdc =
3. Sensor fan...???
1. relay 12VDC, rating ampere lupa bos.
2. u can use anything small transistor for Q1,but remember of NPN. for Q2=tip32 / anything PNP.
3. sensor fan, no use. automaticaly detect from out amp.
4. NTC 10K to heatsink, heat protect. but this protect work fine without it.
schematic of sensor fan attached.
thx. regards
thx. regards
Thank you sir...
- 1000W Simple PA Amplifier
