This is aimed solely at those owners and potential future owners of first-generation Klipsch Jubilees that want to upgrade them to meet and/or exceed the acoustic performance of second-generation Jubilees (pdf attached).
EDIT (31 July 2024): Those owners of 2nd-Gen (Heritage) Jubilees can also access assistance here in getting those loudspeakers dialed into their listening room environment. There is a real need to do this with virtually all home-sized listening rooms, as the fixed factory settings in the Heritage Jubilee DSP crossover will likely be overwhelmingly imbalanced below 40 Hz. I've also found that "room correction software" packages like Dirac and Audacity have systemic issues in the room transition region (a.k.a., Schroeder transition region) that seems to consistently produce unbalanced results for these type of loudspeakers.
EDIT (27 April 2025): I now have a Xilica XP or XD series processor configuration file, otherwise known as an *.xdat file, that has the necessary PEQ, crossover filters, and channel delay corrections to dial in a stereo pair of Heritage Jubilee with Axi2050 drivers - also known as K-694 drivers.
Send me a message if you have interest in changing your fixed Klipsch DSP box with another third party DSP processor or PC-based DSP solution (e.g., CamillaDSP, etc.). The settings in this configuration file use something known as a "zeroth order" crossover, which has no all-pass phase growth due to the crossover filters themselves. This allows the user to possibly avoid using FIR filtering to further flatten the phase response of Heritage Jubilees.
Chris
Chris
Well written. Clearly synthesizes your knowledge gained of so much experience. Makes me want to build a coupla SPUDS. And I'm already using DTS-10s behind my first-gen Jubes Nicely done Chris!
I added a standalone document that describes the integration of the Celestion Axi2050, its measurements, and subjective listening impressions. This pdf document also discusses the subjective impressions of the throat-mounted "phase plug extension". This is information that was migrated from another audio forum for ease of access and assumed better longevity of archiving reliability at this site.
Lastly, I added a 3-D print file of a open-source phase plug extension for local 3-D printing. Various estimates have been ~$100 (USD) to have these printed by a 3-D printing service.
Please let me know if there are any issues understanding the information contained in any of these documents.
Chris
Chris
Updated the Celestion Axi2050 pdf after finding an apparent MSWord problem with expanding figure titles.
Is the phase plug specific to the Axi2050? Would there be any advantage to using it with a TAD-4002 or does it have to be specifically designed for the CD in use?
The "phase plug extension" (i.e., more like a throat diverging lens) I know works with TAD TD-4002/K-402s and BMS 4592ND/K-402-MEH. That's actually how I know it works as a lens, and not so much as a "phase plug extension".
That would have an effect on any future attempt to patent the device (which haven't yet been disclosed), since it clearly isn't a phase plug extension used with drivers other than the Axi2050.
Chris
Chris
I just posted an update to the "Best Compression Drivers today 2022?" thread detailing the now-revealed patent pending status and pdf of the patent application of the "phase plug extender". If and when that patent issues, you can be sure that the 3D print file at the top of this thread will disappear.
Just FYI.
Chris
Just FYI.
Chris
Rereading the provisions of 35 U.S. Code § 154 - Contents and term of patent; provisional rights, section (d) Provisional Rights, (1) In general:
Chris
As such, I have taken down the 3D print file of of the "phase plug extension" previously posted above.In addition to other rights provided by this section, a patent shall include the right to obtain a reasonable royalty from any person who, during the period beginning on the date of publication of the application for such patent under section 122(b), or in the case of an international application filed under the treaty defined in section 351(a) designating the United States under Article 21(2)(a) of such treaty or an international design application filed under the treaty defined in section 381(a)(1) designating the United States under Article 5 of such treaty, the date of publication of the application, and ending on the date the patent is issued—
(A)
(i)
makes, uses, offers for sale, or sells in the United States the invention as claimed in the published patent application or imports such an invention into the United States;
Chris
Just FYI.
Chris
Actually, it is an external phase plug extension. That what I call it, you know…….since I kinda came up with it.The "phase plug extension" (i.e., more like a throat diverging lens) I know works with TAD TD-4002/K-402s and BMS 4592ND/K-402-MEH. That's actually how I know it works as a lens, and not so much as a "phase plug extension".
Chris
Good move in taking it down….I just posted an update to the "Best Compression Drivers today 2022?" thread detailing the now-revealed patent pending status and pdf of the patent application of the "phase plug extender". If and when that patent issues, you can be sure that the 3D print file at the top of this thread will disappear.
Just FYI.
Chris
Just noticed the post by, uh, you know, and am kind of surprised something like that could have a patent on it.
Rather basic piece. The word generic comes to mind. Of course, we live in a world where the clever think they can patent words that are in the dictionary.
Of course, I know you are a gentleman and have no desire to engage in schoolyard antics.
Oh, well ...
Oh, well ...
Thanks Chris! I've been appreciating your detailed contributions on other forum posts also.You're very welcome--and welcome to the forum.
Chris
I have two axi2050s and an EV DX38. In your experience, do you think I would be able to set up these drivers accurately enough with the DX38 compared to the Xilica? The DX38 has fewer EQ points to play with I believe.
The EV Dx38 (of which I still own one) has fewer output channel PEQs than the Xilica XP/XD series, so the balance of PEQs that might be needed for the HF channels have to come from the input channel PEQs (i.e., before the crossover filters). If your bass bin doesn't require very much EQ correction, then the Dx38 should work. In the case of the Dx38, I would try to minimize the use of closely-spaced (a.k.a., competing) PEQ settings, since it will tend to "lock up" if too many PEQs are too closely together and at too high gain.
Chris
Chris
Thanks for the advice. I happen to have a second DX38 so perhaps it would be better to use one for HF and one for LF in that case. I didn't realise that about locking up, very useful to know.
Just a note in passing: based on an extensive dial-in trial using a Heritage Jubilee (the expensive second-gen one) and a miniDSP Flex crossover, I cannot recommend using this crossover for Jubilee duty as it apparently has unavoidable audible distortion. If you want more information on this subject, send me a personal message.
The best DSP crossover that I've tried myself thus far for Jubilee duty or K-402-MEH duty has been the Xilica XP or XD series. I'm told that the successor to the Xilica XP/XD series is the Solaro (a Dante-based processor), and that its performance on a pair of K-402-MEHs is superior to even the XP series (...although I hear no defects at all with the XP series, which to my ears is totally neutral). The XP series was available in the US for about a year or two after Xilica apparently ended sales worldwide elsewhere, but I believe even the US availability has dried up. It was the apparent price/performance leader for Jubilee-capable loudspeakers while in production.
Apparently the Solaro with two plugin I/O modules/cards is about twice the price of the original XP series...making it a few more dollars than the XD series--about $2K to $2.5K--about the price of a used First Watt amplifier.
I do not recommend trying to use cheaper DSP crossovers with the Jubilees, either the first-generation Jubs from ca. 2006, or the second generation Jubs from 2022 to replace the Klipsch-provided DSP box that has a couple of serious issues, like 1) it is a fixed DSP box that cannot be used to dial-in the Jubilees in-room (including trying to correct for far too much deep bass boost for most home hi-fi listening rooms), and 2) it uses uncompensated steep IIR crossover filters that wrap-up the phase and group delay response to audible distortion levels. (For the price, Klipsch could have easily provided a FIR-filter box with flat phase/group delay response.)
I've heard unanimous complaints about Klipsch's DSP box to date. If you are trying to deal with this using a pair of Heritage Jubilees and want to try another DSP box to solve these issues, shoot me a personal message and I can provide settings information and dial-in email support (using something like REW as the acoustic measurement app) to custom dial-in the Jubs to your room's acoustics and loudspeaker placement in-room. The difference in subjective sound quality is said to be a dramatic.
One more bit of information: if you happen to acquire Heritage Jubilees and you presently own a pair of TAD TD-4002 compression drivers, I recommend hanging on to those TADs. If you wish to discuss this further, send me a personal message.
Chris
Chris
I would add, for those thinking about using the SOLARA with DANTE (you do not have to get the DANTE card if you are going to use the plug in modules), my experience.
You can no longer get AES EBU modules. Which led me to the next step below.
Consider getting something like the FOCUSRITE REDNET 16r. With this you will have an XLR AES jack that you can use as the input and use the DB25 cables for 15 outputs.
A MUTEC MC3+USB is connected to the AES input coming from a music computer with all files resampled to 24/96 so there is no conversion required down the line. All remains digital from the computer to the DACs. There is a 10HMz clock from Andrea Mori connected to the MUTEC. There is a clock line from the MUTEC to the FOCUSRITE box.
To use DANTE one needs a good managed switch. A small CISCO (that you can get from AMAZON) is set up using the DANTE recommendations.
For LP I am using an RME ADC which goes to the MUTEC and then to the rest.
It is not cheap even when I got my Focusrite box used. I am not a BURMESTER customer so my definition of expensive is somewhere in the middle.
I started out using the plug in modules - if anyone wants some. When they stopped selling the AES EBU modules I knew I had to do something different and that led to the FOCUSRITE and using the DANTE card. I got the XILICA as a returned item. It had the DANTE card and that was thrown in. At the time I never thought I would use it. Very skeptical of what it would do to the signal. I liked the idea of the blue front panel instead of the black.
Never looked inside the XP box but the SOLARA is using a smps. I think some speculated the XPs had a linear supply. I would tend to doubt it but I never removed the cover of the XPs. You have to open the SOLARA to get to the plug in cards.
DANTE is nothing to fear. It sounds transparent to me and it makes making changes to a complicated system easy.
I would think Chris A could really use it.
The SOLARA offers immense capabilities compared to the even the "largest" XP series. I used two smaller versions based on Chris A's recommendations.
There is not much written about this device so I thought I would try to make up the difference.
- How to upgrade your 1st Gen Klipsch Jubilees to 2nd Gen (Heritage) Jubilee Acoustic Performance
