Not sure how audible that is, really. I have a Q=1.8 peak filter set to -4 dB at 320 Hz in miniDSP Flex 8 & am running the WO24TX as a low mid 125~800Hz. Sounds great.I have been looking at the WO24TX and read the review on @HiFiCompass . Looks great for up to 500Hz other than the little resonance found at 400Hz. I wonder about its significance, if any.
https://hificompass.com/en/reviews/satori-wo24tx-8-95-textreme-cone-woofer
Actually, it sounds good enough to run it way higher -- 3 khz -- if you're not obsessing about directivity. My 4 ohm samples are quite linear; between 800 and 3.2 kHz, it's probably +,-2 dB.
Here's an on axis sweep in REW (with no smoothing other than what REW automatically applies) --
Note, the above curve with the driver on a 15.5" wide open baffle, Hence the early roll-off below ~250Hz.
I also had no problems with the 34NRXL at those relative high crossover frequencies. There is it's disturbance a little higher in frequency but it never occoured a problem in the complete speaker design or sonically.The SB34NRXL can definitely do 500 hz 2nd order with the M74A.
Do you have the driver on hand - could you perform THD over frequency measurements at different levels, similar to mine?I'd rather use the B&C 8NDL51
I'm happy with my drivers for home cinema use but when adapting for PA the B&C would be interesting.
Active for the measurements, I believe 4th order - but I'm not 100% sure. The passive design was finally 2nd order.How steep are the crossovers used?
But for studio/music listening use I only use the active design.
WO24P measures also very good in that range and is significant cheaper. When using up to 1kHz it's the TX membrane. Up to 500Hz ... not sure, should not be THAT much of a difference.I have been looking at the WO24TX and read the review on @HiFiCompass . Looks great for up to 500Hz other than the little resonance found at 400Hz. I wonder about its significance, if any.
Kartesian - it's sometimes a mixed bag. I use their 8" for my home cinema - has a more detailed sound as the PHL, PHL was amazing for voices.
But not all of their drivers are up to the price in my opinion.
Is there a basic difference in cone composition between NRXL and NRXS models?I also had no problems with the 34NRXL at those relative high crossover frequencies.
I used the 8" SB Acoustics SB23NRXS45-4, first in a compact 3way, crossing at 500hz to Vifa NE123w mid, that then got modded to a 4way by adding a warmer sounding 6.5" mid-bass, crossing (passively/expensively) at about 180hz. This just says something about personal taste that can't be seen in measurements. I thought the SB Norex cone sounded too dull in the lower mids. Others obviously think differently.
I realize that this thread leans towards expensive builds and preferences, so I realize that I may be a bit out of context here, but: I also seem to like certain very lively 8" and 10" pro drivers in the 150-500hz range, especially. To me, they make acoustic instruments come alive. A large, light, well controlled cone makes acoustic guitar, or drums, or (or?) seem very "present" and realistic---- at least compared to, and in the context of, an amplified concert experience that uses a good sound system.
Three 10" examples I have: Vintage JBL2251J and JBL2123H 10" midranges, and the higher Q, inexpensive, Faital Pro 10FE200, which is called a woofer, but definitely needs bass support for full-range use in smaller cabinets (I like it in a dipole). Maybe Faital has less consistency in specs, as some have said, but I really like the warm tone of these affordable 10" drivers.
I also like some more "mellow" sounding speakers I have built, and some commerical designs I have modded---these are fine for general music enjoyment, but they tend to "excite" me less. Maybe a higher sensitivity, dome-mid, design is in my future?
Yes, I have been feeling badly about any movement of the thread in that direction I have caused. I suppose 3-ways with dome mids will tend towards more expensive in general, but I am sure that great speakers can be built without spending crazy amounts.I realize that this thread leans towards expensive builds and preferences
Truthfully, some of my willingness to spend on this project is related to the stage of life I am in, that I have been thinking about an ultimate build for years and years. I also am willing to spend money to make up for inexperience and engineering talent, e.g. at this point I would probably spend more to have a driver well-behaved well beyond where I would use it (sort of alluded to by @IamJF above) just to make the crossover easier (or less likely for me to screw up).
Nonetheless, I hope my musings don't dissuade people from participating in the thread.
Bill
Yes, it seems so on the measurements I have been able to find. I just wish I could see some good measurements on the vKi line, they seem to have gone all-out on the engineering of those.Kartesian - it's sometimes a mixed bag.
I have been thinking along this same line for the future, but right now it makes more sense for me to hone my skills further, and also to conserve money. Also, a big piece of it is that when I finish a project, I tend start another one. Many of us probably have the tendency to be perpetually imagining the next project.Truthfully, some of my willingness to spend on this project is related to the stage of life I am in, that I have been thinking about an ultimate build for years and years.
My dad, who passed in 2010, wanted to hold-on to parts for his cherished project-to be, when he was past the point of physically being able to actually accomplish anything of the sort. The imagined future is most believable and promising when we have hopeful plans for it.
I have one older build that is in a continual state of (mostly mental) revision, largely because my expectations and knowledge have both increased over time. Also, I put the wagon before the horse with the woodworking back in 2016. I did build a prototype; but did not do thorough testing---I knew less about testing, crossover building and driver properties at the time.
For folks that are just learning about 3ways, without a big budget, it is probably best to use a cone mid that is well behaved, with a woofer that rolls off gracefully, and just about any decent quality 1" dome tweeter. There may be a few such folks reading here. When that works out, then try one with a mid-priced dome---unless $$$ is no-issue.
Kartesian provides very extensive measurements in the datasheets, like Purifi:
https://www.kartesian-acoustic.com/_files/ugd/f62092_f4db69c69657404f8edce8f61ada3010.pdf
All great points/thoughts. And yes re. perpetually imagining the next project. If the next project involves another speaker, then an incremental approach with a mind to conserving money makes perfect sense. I have (always) many projects floating around in my head, but thankfully it is not other speakers, so hopefully the speaker-building desire/quest will be satisfied with this one. Part of my quest for sensitivity is based on the tube amp design in my head, but it may not be practical, as active might be the most straightforward approach with this build.
Loved this.My dad, who passed in 2010, wanted to hold-on to parts for his cherished project-to be, when he was past the point of physically being able to actually accomplish anything of the sort. The imagined future is most believable and promising when we have hopeful plans for it.
Definitely. Especially with all of the Klippel data. Perhaps the one thing I would like to see is a zoomed in graph of impedance/any other measurements that would uncover any resonances in the intended passband. Though I am probably just splitting hairs- all of the drivers discussed are in their piston range up to 500hz.Kartesian provides very extensive measurements in the datasheets, like Purifi:
@IamJF Yes, I have that one. I'll need to go through my storage section. I'm recovering from a bad GI infection, so I'm still a bit slow and need to catch up. My 8NDL51s have a spider mod that I perform to reduce motor noise in vented applications. I add 8 1/4" holes to the spider edge.
From my tests I would not conclude from the quality from one model to an other model. The NRXL is outstanding of the series, most other bigger drivers are only subwoofers.Is there a basic difference in cone composition between NRXL and NRXS models?
I used ScanSpeak metal membrane 20cm drivers before and from a quick listening comparison I would not say you loose any detail. They sound more "tight" and precise at low frequencies - but it was not a perfect comparison, different positions in the room. When going higher to 1kHz or above I would for sure use TX drivers.
Absolutely! My first version of this dome midrange journey was with the Dayton 2" and Seas 22TAF - also sounds very good but can't bring the SPL I need/want. The Daytons go pretty low and are relatively easy to use - but have a LOT of resolution, for nice listening too much.I suppose 3-ways with dome mids will tend towards more expensive in general, but I am sure that great speakers can be built without spending crazy amounts.
When working with midrange domes you need to be more careful with selecting your LF driver cause it needs to play higher. But it's not per se more expensive. Until you want one of these 3" beasts and a Beryllium tweeter ... and you WANT these at one point at the journey 🤓
Although it would be nice to have someone independent to test it. Driver is great, but price is quite high, and Fs is too for a woofer. One can wonder how much would distortion rise above 200Hz with softer suspension.Kartesian provides very extensive measurements in the datasheets, like Purifi:
Maybe use an active/passive approach with the tube amp for the mids and treble (crossed passively). This way have powerful bass, plus the "tube sound" for the upper section, and not be too complicated.Part of my quest for sensitivity is based on the tube amp design in my head, but it may not be practical, as active might be the most straightforward approach with this build.
Yes, thank you. Something I have been thinking about. Perhaps a project for down the road when I get restless again. 🙂Maybe use an active/passive approach with the tube amp for the mids and treble (crossed passively). This way have powerful bass, plus the "tube sound" for the upper section, and not be too complicated.
I went ahead and ordered the Purifi PTT10s yesterday. As I am building matching L/C/R, if I go fully active I am looking at 9 channels of D/A and 9 channels of amplification(!). The appeal of fully active is definitely there, but wow…
I think my plan is to start building (actually I need to start researching the best waveguide, probably 104mm), then full measurements, then simulate in VtuixCAD, determine if 3 way passive is doable v passive M/T and active with W as you describe, etc. A two channel amp per speaker channel certainly cuts down the amplifier channels a bit, anyway.
Just my musings 🙂
Bill
I most often picture separate amps and lots of wires for fully active, but there are some 3way DSP plate amps (Hypex?) that could make the finished speaker/system simpler to have in a room. Seems like you would always want a cap inline with the tweeter anyway, so maybe passive there?I went ahead and ordered the Purifi PTT10s yesterday. As I am building matching L/C/R, if I go fully active I am looking at 9 channels of D/A and 9 channels of amplification(!). The appeal of fully active is definitely there, but wow…
Class D seems to keep getting better, so the appeal of amps that are not built into the speaker is there in that respect.
- The dome midrange thread
