Dartzeel amp schematic - build this?
I tried to install the sanken 2SA1859/2SC4883 driver.
Every scope picture should contain the information about frequency and amplitude settings and the load should be specified.
I notice a contradiction in post 2374 "Amplitude 10 volts" compared to the photo.
It is hard to decide the blurry pictures hint at an additional problem or its is only the deviaton in crossover range.
Apart from that we can not know which schematic you used and it is modified or not.
In a circuit like in post 7 bias is dependent on the choice/type of Q9..Q12 and the CCS setting in Q90, Q100.
If you test with very high frequencies and high amplitude it is possible to destroy the output.
Do you refer to the schematic in post 7 ?
Current in Q7, Q8 has no influence on output bias.
"10 volts in the cell" what does this mean ?
"Distortions occur in the voltage amplifier" so how can we know where you got your scope pictures ? The output stage has no feedback, but the voltage amplifier has.
Вы уверены, что ваша печатная плата Ali и используемые вами детали соответствуют посту 7?
В противном случае мы будем ходить по кругу.
Yes, I checked EVERY part.
And I'm trying to find transistors. 15032 is about 110, 15033 is about 140, you can't say more precisely.
I have about 50 pieces of 15033 and about 40 pieces of 15032. 🙂
