Pearl 3 Burning Amp 2023
BTW........
If anyone´s interrested in 2SK2145 for P-3.......
just PM me 😉
Sorry for the shady artwork.
Try and see, if this answers your questions 😉
And of course....... All RCA´s "cold" isolated from chassis as well.
Does it matter???
Anyway..... did it with a 4-lead wire....... No shield.
I tried your configuration: slight hum on the right, strangely no hum on the left, and very slight noise in both channels... with other configs the same.
Next step: chassis for the PSU...
Reactions: Boydk
Strange with the "No noise/hum" on one channel only.
The slight "hiss" cannot be avoided. At 70dB amplification small hiss is unavoidable.
First you should look at any..... as in ANY difference in connection between left and right P-3 board.
If you´re absolutely sure, there is none, then yes....... PSU in separate housing 👍
Reactions: Plott
No, there is absolutely no difference. The only one if I will is that the signal cables are crossing each other (without contact) in the right channel, but being shielded cables it can't be an issue.
Now I even removed the psu board grounding but no change.
Parts for the psu chassis ordered, and I will use a shielded, 1.5 m long cable.
However, I noticed a strange thing... I use a grounding block where all my components are grounded. Connencting the Pearl's signal ground to the grounding block causes a loud hum. Funny...
@Plott Optimal grounding arrangements with your setup will depend how the rest of your kit is grounded.
The alternatives are variations on the connection between mains earth and signal ground. From a low resistance to no connection.
Try them out and see what works best.
Btw when you say you use a grounding block for signal grounds, what does this do? If it is an additional connection between all the signal grounds, isn't it creating a signal-ground loop?
Reactions: Plott
Thats a serious rcrcrcrcrcrcrcrrcrcrcrcrcrcrc you have there boydk, .. works well, and then feeding the pearl regulator, not much left, im unsure of pearl pssr, but with 50-60db gain its needed..
Hehe...... It´s works beyond expectations.
One of my previous builds had UDP-like psu´s adjusted to 19 volts before "hitting" the Pearl. No lack of PSSR.
Despite that, this build sounds better, and is my most well sounding and most noies/hiss-frre build to this date.
I´m satisfied beyond expectations.
All this fine tuning, component selection and matching, and settling for your preferred opamp really brings out
all the best in Wayne´s Pearl-3.
I really meant it, when I said, that this has to be the DIY-gadget og the decade :wave2:
Reactions: Plott
I had an ai calculate some scenarios..
First scenario.. 8 by 8 capacitors 35v 1000uf.. all interlinked.
Second scenario.. 8 by 8 capacitors all with 1r in between.
+-/15v 200ma current draw. Dc is infused with 200mv ripple at 45khz.
All-parallel board
64 × 1000 µF in one big lump gives you 64 mF and almost zero ESR. At 45 kHz the rail impedance is so low that the 200 mV ripple is beaten down to the low-µV/mV region, limited only by the regulator and the wiring. There’s essentially no DC drop, but the in-rush current is savage (> 100 A), so you need a soft-start resistor, NTC or relay.
CRC board
Split the bank into eight blocks of 8 × 1000 µF and put a 1 Ω resistor between each block (7 Ω total). Each RC section has a 1 ms time constant, so 45 kHz is far above the corner and each step adds about −67 dB. In practice you can hit −120 dB or better, which is overkill for audio.
Price you pay: the 7 Ω chain drops V = I R = 0.2 A × 7 Ω ≈ 1.4 V on each rail. That’s 0.28 W of heat per rail and your ±15 V shrinks to roughly ±13.6 V.
How much headroom?
Add at least the lost 1.4 V plus a little safety margin. Feed the CRC with about ±17 V (34 V total) so that, after the resistive drop and normal regulator overhead, you still have a clean ±15 V at the load.
In short
• Parallel bank: dead-quiet, no voltage loss, just tame the turn-on current.
• CRC chain: even quieter, but wastes about 1½ V and some heat; raise the raw DC to ≈ ±17 V if you insist on keeping ±15 V out.
Reactions: Plott and stajo
