DIY Lightweight 5-meter tall Delay Tower PA System
I'm working on a portable, cart-based PA system for outdoor events.
Covering crowds of thousands is a huge challenge, and it is crucial to get speakers high into the air so the acoustic energy is not absorbed by the crowd. I have found line of sight between audience members and the PA is critical for intelligibility. I am mostly concerned with speeches, so bass response is not important.
In the pro audio world, they use line array towers hoisted high into the air to cover large events, with similar "delay towers" deeper into the audience to reinforce the sound with appropriate delay.
I am hoping to emulate this somewhat with a low cost, lower quality system that can be easily set up and taken down.
I am happy with my current version, but excited to make a few improvements to the horn design and the DSP programming.
The system uses a two-way speaker design where the mid/high horn is mounted as much as 5 meters(15'ft) above the woofer. I am using very strong telescoping carbon fiber cleaning poles as the masts.
Here’s the current signal chain and driver setup:
  • 2x JBL Selenium D250-X GW 1" phenolic compression driver (1-3/8"-18 TPI)
  • 2x PRV Audio ADM25-50 adapter (to 4-bolt 2″ horn mount)
  • 2x Goldwood GM-450PB horn
  • 12" woofer (Behringer b112d, removed old(broken) amp, not using tweeter) near ground level to fill in 50hz-400hz
  • DSP via Dayton Audio KABD-4100, handling crossover, delay, and EQ (using REW for auto eq)
I’d like the horn to preserve the 90° x 40° pattern, and be able to cross over around 400 Hz.
In my tests it sounds good as long as one is standing in the coverage zone of both the woofer and the horns. It is very intelligible, though far from "full" sounding as the lows are pretty underpowered.
By using two of the horns I can point to 180° for large crowds. I have access to a printer with 350*320*325 mm³ Print Volume, so ideally it fits in this space.
Making the horns sound better and weigh less would help even more, and let me raise them higher safely. The horns are connected with all-metal hardware and each has backup safety tethers to reduce head injury risk.
I’m currently using an injection-molded Goldwood GM-450PB (90° x 40°), but it’s far more rugged than I need. They also rely on an adapter which I imagine harms the sound somewhat.
To keep things manageable, I’m trying to make the horns as light as physically possible, I'd love to print them in PETG.
The horn geometry stuff is frankly terrifyingly complex to me, and I wonder if I could get help creating a single-surface STEP file of a horn with similar or better frequency performance, which I can thicken in Fusion to to be printed in one piece.
Also would love to hear thoughts on the project!
Thanks!
Reactions: stv and GM
Ah ah! You mimic that situation in your little space
I mean...you should overcome the distribution of sound in say- a 20x 20 m area - with enough power and even covering the audience with full spectrum radiating sources that can be subdivided into units with specific drivers for the given function.
I don't see the typical subwoofer (array- coz' it's never enough) and head system, just a too stretched in height dismantled system.
The idea is good - sound from a 45° source above the head.
Experiment can be done with the existing speaker. The problem is how to suspend a mass.
I fear some problems below the Schroeder's frequency (?!) may arise. Some speculation about WHY in the Altec's VOTT the HF horn is near the woofer horn, and what's that woofer horn?!
Absorbing acoustic energy by the crowd is not a problem, with correct aiming. High mounting is a good choice because you are using simple point source speaker to fill large area with more-or-less uniform SPL. What is the expected distance form your pole to the nearest crowd? Line arrays have multiple modules in high (long) segmented column, where lower module or two (or three) can be pointed downward to the nearby crowd without overpowering them with high SPL, while upper multitude of line-array modules are pointing to the crowd farther in distance, providing the same SPL far away.
It is not clear to me - are you also intending to use several your pole-mounted systems to cover larger area farther in the crowd, with appropriate delay?
Although woofers are attached low enough to ensure low center of mass, everything is looking flimsy and dangerous for use in the crowd. What is the safe carrying weight of that tripod? What about powerful wind gusts?
With woofers mounted that low (from the ground), all frequencies in the 300-400Hz range will be absorbed by the crowd, reducing intelligibility. There is a reason why line array modules have low frequency extension to at least 100 Hz. What is the expected distance form your pole to the nearest crowd?
Those poles are not designed or rated for overhead weight support, and show considerable deflection in your photo.
They will wave in a slight breeze, and are unsafe.
If you plan to suspend speakers in the air above a crowd, your rigging should be certified, and you should carry liability insurance.
To preserve a 40 degree vertical pattern to ~400Hz, the horn's height would need to be around 1meter tall.
To be non-resonant, it will be heavy.
Reactions: Scholl68
Thanks for all the thoughts!
Safety is the number one priority, and is being taken seriously. The image is not current. Each 3 kg horn (7lbs) in the current version is on its own extension pole. Each pole us rated for 6+ kg, and the poles are only being used ay 75% extension, which cuts the torque moment in half. Additionally, I hope to cut a lot of weight from the horns by printing them. The photo is both not the current poles, and some of the curve is an artifact of "panorama" mode on my phone. The area under the tower is kept clear and the operator is careful to raise less high in winds. Also the current version has 20+kg (50+lbs) of ballast in the base not including the woofer. I have done extensive tipping simulation and real-wold tests and the tower self-rights when tipped to 15° from vertical, which is one standard for tipping safety for equipment stands in industry. Overhead weight is no joke, and I assure you precautions are being taken.
In an recent actual use example, furthest audience member is 100 meters (300ft) away from the main sound system, which is 4 12" full range active PA units on a 2m (6') stage platform with 2m (6') tripod stands.
This system is the delay tower, it was set up by ear once the main system could no longer be heard clearly, about 50m 150'ft away from the stage. The delay was set to ~150ms to account for speed of sound.
The crossover point was picked to be as low as could practically be emitted in the vocal range by a extremely loud speaker without it weighing too much to safely be hoisted to these heights. The goal is to ensure everyone can understand the speeches, not to win any sound quality awards.
It sounds fuller than I expected, though definitely a bit shrill. I have the DSP set up so the woofer is redlining even when the horns are not to make up for the imbalance somewhat.
Is there a ideal place in the forum to ask for CAD horn geometry help to lighten the horns, and perhaps improve the low end?
So, just a delay filling, farther in the crowd. OK.
Because this pole is in the middle of the crowd, woofer output between 300 and 400 Hz will be absorbed by a nearby crowd - that position of the woofer is not good. I would suggest to build new, smaller enclosures fitted with the same woofers (or preferably with lightweight neodymium magnet versions), attached at the same height next to the midrange horn. Bass enclosure should be very small (just to enclose the woofer), because you don't really need any output below 200 Hz. And of course you need a proper rigging system to put those loudspeakers high enough. Fiberglass pole and simple loudspeaker tripod are not serious nor professional.
I agree with Sonce and others that this pole and tripod solution is not safe enough, whether you have tested it or not, sorry to say. When dealing with crowds, you can expect the unexpected and Murphy's Law is waiting for something to happen. Is it possible to use a multitude of distributed smaller speakers, that are placed much closer to the ground, instead of one high up? Or use a trailer or heavy cart to attach a strong enough pole?
I truly am taking the safety of this system seriously.
The original tests(photo) were done with a commercial fiberglass antenna mast that is rated for over 3x the load being used, when the mast is also not even at 75% height. Compared to the fiberglass mast (pictured) the carbon fiber pole is more rigid, stronger, and being used with half the load of one light horn each. Everything overhead has a safety cable to account for hardware failure. I am wearing a hardhat in all of my tests. The rig is being used only in constant attendance and with no audience members near by. In my view as a mechanical engineer, the rig is safer in its current configuration than an average 15" PA on a normal 2m (7'ft) speaker stand, which will not self-right if tipped 15°. Having said all that, you are right the current poles do not have ratings and I will explore stronger poles with appropriate TÜV ratings such as the Manfrotto 269.
I posted here with the hope of getting all kinds of feedback, and I am grateful for it!
I am especially interested in making the horns even lighter to allow for a greater safety factor. The drivers are only 1.2 kg (2.7lbs) and I bet a printed horn could be less than 500g.
In terms of improving the bass response, my thinking is that only a compression driver can produce the SPL I need while not weighing a lot. Anything I can do to help the exisitng drivers reach lower frequencies would be really helpful.
No, it is not.
Proper rigging will not allow 15 degrees tipping.
Maximum load for Manfrotto 269 is only 10 kg, in still air. Wind is not taken into account.
The main problem is wind, not weight.
You can't cross D250-X below 400 Hz. Even 400 Hz is a big stretch - 500 Hz is the minimum crossover per manufacturer recommendation.
The only way to produce bass below 400 Hz is by conventional cone woofers.
Actually, there are/were many good old PA horn drivers that can go well below 400Hz, and get loud enough to cover 1000 feet or more with no additional delay speakers, as was the case in the 1963 March on Washington using manifolded drivers on RCA straight horns:
The RCA MI6341 was 4.5 feet long, the MI6442 was 6 foot, 250Hz Fc.
More current offerings like the TOA TH660 re-entrant (folded) horn has a usable range from 250Hz-6kHz:
For speech only applications, re-entrant PA horns with proper equalization still are often the lightest, loudest and most cost-effective solutions available.
Art
I did wind load calculations before ever setting it up, even in 50kph (30mph) winds the small 0.1m^2 surface area (~1sqft) means the side load is only about 1kg (2.3lbs). In high wind conditions, this project will stay home.
I wondered what the limits of this diver/horn is. I would have to look at the DSP file, but I think I have it set to 500hz or so with a 12dB curve.
So cool Art! thanks for sharing. I have often wondered about this very event and how sound was covered. I wonder if people could really hear all the way in the back. The speeches are so inspiring, and based on the recording we have all heard, very intelligible, although not so strong in the bass region. 🙂
I used Pyle folded horns a lot for events years ago and they always sounded bad, though the efficiency and throw was amazing!
TOA seems to make some very relevant stuff! here is a $55 driver that goes down to 150hz. I saw a non-folded very large TOA horn somewhere online that I thought about. It is exciting that it goes down to 200hz! But I think keeping things small and light is my current priority.
Is the basic geometry of the Goldwood GM-450PB as good as it gets for my application?
I chose the D250-X because it was small and light and had the lowest frequency I saw of anything in its size.
I even saw some heavy and expensive 2" drivers with not-as-low performance. But there are also even more expensive and heavy drivers with low-freq support.
I picked it after calling PartsExpress and explaining the project. It had the lowest frequency of anything the tech knew of.
Based on what I have seen about HornRESP it seems potentially best to generate geometry to suit an application to reduce distortion and maximize response. if it weighs less, and looks cool, thats event better.
Yes, of course, but not in this case where the weight and bulk are limiting factors.
The TOA TH-660/TU-651 aluminum horn/driver only weighs 5.5kg (12.1 pounds) and is 600x532mm (23.6 x 21 inches), yet can do over 125dB/1meter with only 100 watts.
In the mid 1980s I bought surplus PA loudspeakers we nicknamed MASH (Mobile Army Surgical Hospital) horns.
Don't remember the manufacturer now, if it even was listed, we painted the army green horns black.
The third section of the folded horn was attached to the inner portion with over center clasps, and could be stacked like Dixie cups.
A dozen of those ~21" diameter horns and their drivers with re-entrant "nose cones" could fit in the trunk of a car, or back of a Jeep.
You don't seem to be considering the considerable wind load on the mast.
Once you have contracted an event, the option to "stay home" is not legally available.
Gusts of 30mph are common, you should be designing for ~64mph minimum.
Using the manifold driver horns, given the calm day and the Reflecting Pool avoiding ground absorption that pair of horns could produce around 58 dB at 2048 meters (1.26 miles), easily heard over an attentive audience.
Not if your application does not include co-locating the woofers with the high frequency drivers required for horns with Fc in the 500Hz range.
Not as nearly as low as a re-entrant horn of similar size and weight.
You need to consider the diaphragm size and it's excursion, the total displacement capability available for low frequency, and the acoustic low pass incurred when the diaphragm to phase plug distance is increased.
Purpose built "PA" drivers may have two to six times more excursion available then those designed for use in higher ranges.
The JBL D350 has a 3" dome diaphragm with no more than 1mm excursion before it hammers the phase plug, which occurs with around 42 watts at 400Hz.
The B&C DCM420 has an annular diaphragm with a 4" voice coil, displacement perhaps approaching that of a 4" dome as used in the JBL 2482 or 2490 mid driver. Note how much larger the surround is on those mid drivers compared to the 2445 high frequency driver.
https://www.parts-express.com/B-C-D...ession-Driver-8-Ohm-4-Bolt-294-585?quantity=1
Most techs are unaware of the displacement limitations of compression drivers, as that specification is seldom published, and must be inferred from power ratings, which are not often given for more than a single frequency.
Looking "cool" does not make an event requiring even speech coverage of an audience "better".
Art
I missed this. ^
Actually, I installed once four TU651/TH660 combos long time ago. I wrongly remembered it has extension "only" to 350 Hz, actually it is 250 Hz - which is excellent. With a little bit of EQ it is easy to get flat frequency response, with slightly rising top end for long distance reach. With good rigging 60 cm (2 feet) horn mouth bulk is not a problem, even in the wind. Finally, the OP problem is solved, thanking to @weltersys.
The depth of knowledge here is really cool. I really appreciate folks taking the time to share their hard earned lessons.
I have never heard folded horns that sounded good, perhaps they were never EQ'd properly. I often find them to be shrill, tinny, and strange sounding.
I, perhaps ignorantly, assumed that was due to their often low-fidelity applications like schoolyard announcements and the reverberation from the thin metal construction. in 2020 I did some larger events, and I used 2x 18" military surplus horns, one 32" military surplus horn, (markings worn off, but thought to be WW2) and 4 Pyle 18" horns with the 70v taps bypassed. They all sounded bad, but I didn't know how to use a DSP yet to EQ speakers, not that I am very good at it now. 🙂
I am happy with the sound of the current system I have built, and if I ever make a rev2 there is a lot of info here to take into consideration.
My takeaways are to pay more for a better driver, one designed for midrange with a bigger coil, such as the B&C DCM420. Also to consider a folded horn, or perhaps a longer one.
I also had the impression that the folding was a compromise-laden way to simulate a longer horn with out taking up a longer space. Is that right, or does the folding have its own benefits?
There is not enough safety factor here, not even close. Please do yourself and the audience a huge favor and stop using these.
Thanks to everyone who’s chimed in — I appreciate the breadth of perspectives, and I want to take a moment to acknowledge the safety concerns that have come up.
First, I hear you. Nobody wants to see poorly engineered gear causing harm, especially in public spaces. I share that concern, and it’s exactly why I’ve been field-testing the system extensively before putting it anywhere near a crowd. Some of the info I shared earlier was inaccurate and out of date — the towers are not as tall as I originally described, though some early tests were done at 5 meters. I was focused on the technical questions I came here to ask, but I appreciate the chance to clarify.
At this stage, the poles are capped at 10 feet (3 meters) of carbon fiber extension, using only the three largest segments (diameters: 37.5 mm, 35 mm, and 31.5 mm). An additional 2 feet (66 cm) comes from a 40 mm dia steel riser, bolted securely to a steel frame at the base and 24″ (60 cm) above it. The system is stabilized with over 50 lbs (22 kg) of ballast, and in practical shove tests, it is markedly more stable than any commercial PA tripod I’ve worked with.
Each tower supports a 7 lb (3.2 kg) horn assembly with a projected area of less than 1 ft². In a 60 mph (27 m/s) wind gust, using the flat-plate drag approximation, even with the narrow mast included, we’re looking at ~11 lbf (5kgf) of lateral load, which is well below the forces I’ve applied manually (tested at 30+ lb (13kg) lateral pulls on long rope at full extension). The pole deflects under load but shows no signs of instability, cracking, or uncontrolled oscillation.
Using only half the original 24′ carbon pole, the system benefits from a significantly higher load margin — likely 3–5× the nominal safety factor, since we're working within the thickest and strongest sections of the pole. The moment arm is shorter, and the flexural stiffness higher, reducing the risk of dynamic failure.
Finally, the base has been tested to self-right at a 15° tilt — a margin well beyond the 6–8° tipping threshold of most tripod setups. Visually and mechanically, the system feels secure — and I say that as someone who’s usually on the cautious, overbuilt end of DIY design.
Having said all that, upon reflection, I am going to swap out the carbon fiber poles and replace them with something all-metal with higher weight ratings for peace of mind.
This steel lighting stand claims 60lb capacity, over 8x my load. I only loose 12" (30cm) of height and I stand to gain rigidity and the ability to consider flying a slightly heavier speaker with fuller range. I appreciate the concerns raised.
That said, I'm still learning, and I'm here because I want to build this as safely and effectively as possible. I truly appreciate people pointing out blind spots — it helps make this system stronger.
What I’m struggling with, though, is the tone the thread has taken. A few replies have felt less like constructive feedback and more like gatekeeping — as though curiosity and experimentation itself were suspect. This forum has a reputation for being a place where passionate people share ideas, challenge each other, and explore weird or nontraditional paths. That’s the spirit I came here for, and I’d love to see this thread return to that mode of engagement. I know I am new, and you all know each other, but a little benefit of the doubt would be deeply appreciated that I am not recklessly endangering my community would be deeply appreciated. ❤️
So with safety concerns on the table and acknowledged, I’d love help with the actual thing I came here to ask:
I’m hoping to generate a lighter-weight horn design with comparable or slightly better frequency performance than the Goldwood GM-450PB, and I’m seeking either a STEP/STL of a horn surface or suggestions on modeling approaches for constant directivity or OS flares for a 1" driver.
Warmly,
