Yup, just like B&O used in their 3way bookshelfs.
Back to regularly scheduled program. Another fine midrange, highly recommended by John Krutke, is this tiny 4" woofer. Yes, they call it woofer. I used it in my short line array long time ago. Its still available, very cheap, yet with very low distortion. Being metal cone, it has breakups, but they are high, easy to filter out. Highly recommended mid.
https://www.parts-express.com/Dayton-Audio-RS125-8-5-Reference-Woofer-295-353
I didn't plan on getting into the details of my build in this channel but one of the features I am going for is using less XO components. Second order only. I want the system to blend more.For example, I've noticed that moving from the cheaper KEF speakers, to the more expensive ones, you get less sensitivity, which could indicate that the smoother response of the more expensive - and better - models, are most likely better filtered than the lower level models, which could mean that they use more components in the filter to make the speaker more smooth and better over-all sounding. So, there is no free lunch. What you have to consider, is whether a given component in your design, gives you more fidelity, than it takes away.
I do understand that crossing lower to the tweeter will improve the off axis. Originally, I was going to use a 7 woofer, to a 3 mid, to a 3/4 tweeter. I couldn't find a suitable 3" mid for some of the other aspects I was going for. There is a Peerless full range 3" but its not going to become available
I need some teaching here. Why is a lower QTS driver with a larger magnet better suited to a narrow/skinny baffle?It appears they use a larger magnet on the midrange. I'm guessing this would move the QTS lower. I think these were designed to go together in a tall skinny enclosure.
I do plan on using these in a rather slim design so I guess that works out
If I understood correctly:Why is a lower QTS driver with a larger magnet better suited to a narrow/skinny baffle?
The low qts mid driver and the long stroke smaller magnet bass driver were intended to work together in a narrow baffle.
I really wanted to use the NE123W-8 but it didn't become available when it was supposed toLegendary vifa was rather good midrange.
Interesting driver. I have two 7s going down low so I don't need the extension. I have not used any Artum Cantus drivers. They seem very expensive for what you get. Maybe they have some special sauce I am unaware of. Sort of the like the Wavecor which seem ordinary until you look at the Q specs and find out they are very special.Wait, there is more...this is actually considered midbass, yes, it can do some bass. I made bookshelf with this aurum cantus which goes down to 30Hz. Not real bass, the cone is light and thin. But where it shines is midrange. Smooth, flat, goes up high enough to be crossed to ribbon tweeter, great of axis, almost no breakups. Used this one a lot. Not expensive, still available.
The GRS 8" Mid planar. Probably the best $65 I have ever spent on HIFI.What exact planar are you talking about?
I am very fond of planars, especially on open baffle, but i have yet to see one which would cover midrange. Most cover only upper mids. Those i used if crossed low distorted. Thats why i want to know which planar you used. Can you show fr response and distortion plots?
Keep in mind while looking at these graphs, that the measurements were taken after an entire winter of screwing around with horns and waveguides. Its not like this if you just screw it to a baffle naked. But its also not super far off
Interesting. I once bought the 2.5 or 3" version of this to use a filler in a limited XO 3 way build. It really sucked. Like really really really sucked. Kind of put me off the whole Dayton woofer line to be honest. Must be like anything else, there are gems and there are turds within any lineupYup, just like B&O used in their 3way bookshelfs.
I use them with Vifa NE225W-08 and Fountek NEO CD3.0. Excellent mid drivers and not expensive. They are almost a full range, and 3.5" rather than 4".I really wanted to use the NE123W-8 but it didn't become available when it was supposed to
Well, well, well. You call that midrange? Its response is droping like a rock below 1kHz! Some tweeters go lower. You were definitely ignoring what I wrote. Midrange driver is flat from 250Hz to 3kHz, I repeat. And it was said by others too.I really wanted to use the NE123W-8 but it didn't become available when it was supposed to
Besides it has terrible rising distortion towards lower frequencies just as i measured myself.
But there is no definite definition of midrange frequencies, except they are in the 'middle of the spectrum'.Midrange driver is from 250Hz to 3kHz, I repeat
The quoted 300-300hz is the old telephone, voice reproduction frequencies.
that is no requirement or and actual feat that most drivers can even do.flat
You need it to be in piston mode
What is the problem with a rising response.
Often it just means that the driver is not rolled off by inductance, which does what? Distort the upper frequencies quite badly.
Or a smooth curvature, as long as SPL is high enough in the intended bandwidth?
Absolutely nothing, just requires a more 'complicated ' filter, as the textbooks solutions won't work great.
Absolutely nothing, just requires a more complicated filter...
Yes, there is no definition. I mentioned that in my first post. It all depends what source you follow.
Flat is preferred, but if the driver is designed with rising response, its fine with me. I used many planars with rising response. But typical cone midrange is flat. That is normal. If cone driver is not flat, than its defective.
I am absolutely ok if you use more complicated filter, its ok with me, you do not have to repeat yourself. You do not have to pay attention to what i am saying.
This surprises me as well. I did use a 2.5" full range as a mid filler and it works surprisingly well.im surprised fullranges are not used more often as midrange drivers
I almost feel like most 3" and smaller full range drivers are really just mid ranges. They just market them as full range. When you look at smaller full range driver's measurements, you'll see most of its meat is in the mid range. They always drop off at the top requiring a tweeter. At least, every one I have tested does. I hear the Mark Audio drivers are better in the high frequency areas than most other fill range driver s
- What makes a "Midrange Driver" a Mid Range?
