USB UAC2+HID Multichannel input/output interface York
It is possible, as 3xI2S or TDM stream.
So if I program York as 3 channels I2S stream, then standard Windows drivers will detect York as 5.1 sound card?
Another question, if I sometimes want to listen to a 2.1 stereo stream instead of 5.1, do I need to change the settings in Windows from 5.1 to stereo, or reprogram York? Will it be possible to switch from 5.1 to 2.1 under Windows without problems? Or does Windows not support the 2.1 configuration?
Now it will be seen as just 2/4/8 channel. To tell windows the exact configuration (3.1/5.1/7.1) a modification of USB descriptor is required. I have plan to do so but it is not there yet.
It depends on the software, sometimes it is possible to override "global" settings in windows inside the app. If you're up to do some experiments, I'll send you Nano board, I think it would fit into your DSP amplifier project. Please send me PM with address.
Reclock board with MEMS oscillators 🙂
In relation to York, just sugestion! 2.54 pins and I2S is not an good option in my opinion, thats an antenna + pickup antenna. And if possible an miniature board like esp32 or bluetooth module, something like this would be very good option for those who need things real modular in much smaller possible form = the better! That case users have choice to have miniature York and other to have miniature board + carier board whith size of current York, that way you have two options for selling and we have also two options for buying! In my case I not like the current size of the York and also not like those 2.54 pin headers. Just my sugestion for your further work on improving your York.
Reactions: eclipsevl
You should use v-cut on the side that do not have holes, and make square pads with oval holes so that you cut the rest of panel yourself, that way I think it not cost twice?
If I understood you correctly, you propose to cut the boards after production to get kind of constellated holes.
In that case there will be issue with metallization - the existing metallization in the holes can be damaged and there will be no metallization on the edge of the board. This is the whole point of constellated holes option.
Reactions: savan
Hi eclipsevl
Just a quick question, could an isolated version of York with a relocking board be used in the 2ch in, 4ch out mode?
Hello,
The reclock board is designed just for 2ch I2S/PCM output, and the ISO version I2S input port can only work as master (because of the on-directional isolators).
So I would say it is not the right choice. It would be better to use non-isolated version and add isolation and clocks on another board to meet requirements of your project.
More specifically how would the 2ch i2s input be delt with in this hardware configuration
The ISO board may still work however with some restrictions:
1. Both In and Out I2S ports must be masters
2. Sampling frequency of input and output must be set to same value (both 48kHz or 192kHz, for example. 44.1 and 48 would not work)
Which ones do you use?
These are SiTime, SiT8208
