300B OT nano, first test
Anyway keep me up to date, your results look really good so far.
thanks for your post
Now I am waiting the second stuff to check the quality with the first and in case do something.
In the little factory there is a beautiful wound machine comes from Switzerland and was property of Da Vinci brand
Regarding the potting I will take note of your consideration; I was thinkin to check one free air and one potted to understand the the specs; there are metal box 13x13x12 cm ready.
In addition there is very good interstage trafo 5:1 for line out and 1:1+1 for p-p drive ( or s.e) with a little irona always nano. Tested very good ( for me)
Then a s.e. for 2A3 / 45 is coming
Ciao
Walter
Reactions: Wavelength
Walter,
I made a bunch of amps with interstages and if your looking for a little bit of compression that works well. When Avantgarde Horns were selling like hot cakes I made a couple of 300B amps doing that and people loved them.
I make a lot of guitar amps that are PP and use a tapped inductor. Feed the plus signal into the dotted end, ground or bias the CT and the non-dotted end gives you -180 degrees. Plus there is no compression. It sounds simple but a little harder to design than winding equal sides. Plus since the two parts are in parallel the inductance drops.
Don't care for the 2A3, most new ones are just 300B's with the filament in parallel. Old single plates are expensive and gassy now. 45's are so much better sounding and VT52. Just shipped a stereo VT52 with silver outputs 3 weeks ago.
Thanks,
Gordon
Crystal-containing core materials* are notorious for their degradation in terms of permeability when they are potted. A brand like Vacuumschmelze noted up to 30% less permeability in their technical bulletins. A brand like Tribute audio potted all their transformers, maybe another brand did too.
As far as I know, amorphous materials don't have such "problems" and neither do nano crystalline materials (or very few)
* all traditional core materials as SiFe or nickel iron (permalloy/mumetall). They suffer from stress.
You don't need to pot transformer with epoxy or silicone, just impregnate them with varnish. Its enough to fix winding and core lamination, and protect them vs moisture.
100Megs on a transformer winding? It's an open circuit. 100milliohms on a transformer winding? It's likely a short circuit in most settings.
Call me an a**hole, but I highly suspect such posts as insulting trolling attempts. I've been following member @waltube 's posts and although there are details of his work where we differentiate, I'd say he's enough of a skilled and talented builder to make a difference between an open circuit secondary and an appropriate valued ohmic loss value (for a 5 Zout secondary winding).
Do I imagine things, or transformer builder discussions tend to burst into ambiguous attacks derived from potentially fragile egos?
Another proto
Nano
10k:10k
25 mA
around 40 H
With beautiful E810F in triode
Ia= 20 mA
Vdc = 240 v
G = 44
22 Vrms out on 10k load with 0,7% THD
some indecision after 40 kHz, will be checked better
