3 way project - final impedence too low
thanks all for your contribution.
It is clear that the problem is the high cap value, but it is not possible for me to reach the same graph decreasing the cap and increasing the coil value.
Reducing cap and increasing the coil I can obtain this result.
That looks like a nice tweeter. I can't imagine it dropping the impedance with a simple filter. Has anyone else had any luck A 3rd, or 4th order at 3k ought to be very easy.
If you want, post a zma, and frd file. Making guesses is getting nowhere.
impedence a little bit worse
It’s a 4Ω tweeter… Of course the net result of your rather big series cap and smallish parallel coil plus the driver impedance is a low impedance at high frequencies. Since you keep thinking you don’t need to pad the tweeter down, this is what you get. Case of underestimating the difficulty of designing a good three way loudspeaker.
Oh, did you already notice? The 2π response of the woofer tips 87-88dB (from the data sheet). The series coil probably gives away a dB too. Will you correct for baffle step? Where does this lead you to?
Reactions: stv and jawen
