Q17 - an audiophile approach to perfect sound
Stef ,
In the past I did get a tip from Hugh Dean ( Aspen Amps ) regarding the use of FQA/PF and IXTQ power FETs .
Solder a 470p and 47R resistor between drain and gate to avoid future problems which could happen due the high transduction of those FETs .
This way you slow them down a bit and protect too for the use in amps .
This is good info. Have had those problems. Do you mean i parralel or series?
Hello,
I was able to run the Q17-Mini through the QuantAsylum test bench.
On 8R load with -10dB input and the 1.2V sensibility config.
Stef.
Reactions: Yurik_V and inyashd
Hello,
The configuration is very simple.
  • One BNC-RCA 1m cable for the output.
  • One 2xBNC-RCA differential 1m cable for the input (to avoid ground loop).
  • Two BNC-BNC 15cm cables for the interconnection of the second channel.
  • A 100W 8 Ohm load.
The 2 x BNC-RCA differential cable can be bought directly on eBay. For stereo testing, you need 2 BNC-RCA cables, 2 2xBNC-RCA cables and 2 loads.
Stef.
Reactions: Chazz
Hi!
A pair of Vishay 100V mosfet.
Q1': SI2328DS
Q4': SI2325DS
With the SMD parts and 60V rails, zeners D2 and D4 MUST BE REPLACED by 16V 1N5246B zener to get 14V.
With the SMD parts, we get -3dB more on the 50Hz rejection.
I replaced Q6 with FQPF3N80C. With the Toshiba I got burst of oscillation > 32V. With the FQPF3N80C it's ok until the clip à 35V.
Stef.
Stef ,don't you mean D3 instead of D4 ?
Reactions: stef1777
