The 'Circles of Doom’... Open baffleless full range speakers
Speaking of my experiences, I stuck with the clamshell configuration because in my room, any kind of baffle...H, U, S, W... increased the bass output, but in a bad way: ie, by pressurising the room, bringing out the modes, resonances, etc....so the subjective bass quality with the clamshells is the best I have experienced with my setup, in my room.
Reactions: Chris8sirhC
Yah...that's how I used the driver for years.
I did post a diagram earlier showing the difference between the output of a single driver and clamshell arrangement. With the single driver, the output spreads everywhere. With the clamshell, there is cancellation at the sides....so there is more directivity. Although output is reduced, so are incitements to room modes.
With my single baffled bass driver, a bass null was created in my listening position. I had to move the sofa forwards 2' to get any bass. No such issues with clamshell, and bass is even everywhere in the room both in volume and throughout the frequency range.
Diyiggy
Never tried the back to back configuration. I think it would lose directionality.
The clamshell configuration gives nulls at the sides so the pattern of bass is like a figure of 8. I think having this directionality is what makes it room friendly.
I have tried different orientations. The one that works for me is having the magnets aligned with the listening axis. Could be my room as my speakers are place along the wide wall in a rectangular room approx 7 x 5m. I know one guy that places magnet on floor and it works for him.
The output from a single 18" vs 15" clamshell would not be so room friendly as less controlled:
I'm confused by the woofer arrows on the right hand drawing. I don't see how the null is created beyond the confines of the woofer, and it wouldn't be a null it would be isobaric. I don't see any difference between the double woofers out of phase than a single woofer. I think the arrows are incorrect. The outside arrows are pointing away from the clam shell but the two internal woofer arrows are moving the same direction. The top woofer arrow is backwards.
I think woofers in a clam shell in phase with each other would create a strong wave around the radius of the clam shell. This would make a stronger cancellation line than if the woofers were placed on a flat baffle. This might work well in smaller rooms.
How does one align these with the midrange for delay? If the woofers are making in phase sound from the front and back how do you integrate the midrange that is making in phase and out of phase sound?
Isobaric, facing each other, with the gap!
@Arthur Jackson ,
I wonder too. And I have no knowledge about that. If speaking below 80 hz where the ears have less acuracy to locate those frequencies comming from a point source :
First : quality of sound vs a H-Frame or a Ripole (which extend around 10 hz below the Fs at the cost of efficienty) VS a Clamshell with no box.
I am assuming at believing experienced diyers than tried everything, that the SQ is winned on : shorter distance for the cancelation due to the lack of paneel surface. And maybe less emiting sound from the panel as there are none ?!
Second, the clamshell behavior with 2 drivers VS same drivers also nude but firering both towards the listener. SQ difference due to the patern only or same.
then theoricaly, only acoustic wise what about only one driver of the same Sd than the two littlierone ? Will we percieve a different SQ.
Really wonder if a ripole of two 12 or a H-Frame with a 18"performs the same below the acoustical resonances of the box, than boxless at iso drivers surface.
It is open baffle with no baffle. It is unwise IMHO. It doesn’t increase directivity it just decrease output. The output in such configuration more or less the same one driver naked or two. The benefit of two just to reduce distortions. But any w frame force cancelling is better solution. You increase spl, reduce distortion even more.
This has nothing to do with this thread.
As I stated earlier, page 11-12 shows the clamshell with a gap between the drivers has the same 6dB increase as two drivers side by side.
