Babelfish F8
Once upon a time, I had a Tesla, however.
This one 😀
Is that the reason for the US-slogan "Drill baby drill"?
I can say that my 2 X F8b have been approved by one of my best HiFi friends. He has never experienced my system sounding that good and he has been very positive about my system before the F8. Especially with woman voices + 3D imaging he was very impressed.
Reactions: yoaudio and yangjie
Hello, sir. I'd like to ask that if I need to connect a pair of large power transistors in parallel for the Babelfish F8, how should I do it? Is it just a matter of adding a pair of IRFP150 power transistors and two large resistors, and then connecting the gate poles (G poles) of the two IRFP150 transistors to the circuit?
build different amplifier
whatever you do to F8, it is still SE amplifier, and not made to drive nails in concrete wall
it can be made bigger, more potent in both current and voltage, but that means redoing entire amplifier .... not just output stage but also front end; single JFet in input stage is not going to be enough to drive more gates
remember that one IRFP150 is practically 2pcs of IRFP240 packet in one TO247 case; can't go much further from that, without said changes
Reactions: schultzsch and Vix
Plus, you don’t want to disturb peaceful pond that Choky relaxes in….🤣🤣
