TH-18 Flat to 35hz! (Xoc1's design)
Anyone that has a 3d file of the design (first version)?
i looked in my stash of sub plans and
i found the last iteration of it drawn by Deman, if you want it let me know,
it is a fusion file, and 2 dxf files CNC ready that have all the panels and bracings
and i found the original plans that do not have the cone correction
but is a PDF, see 4th pic from top to bottom.
hi max, i would like to build a couple of these th18. your files would save me a lot of time, since you also have the cnc files ready. Unfortunately i can't write you privately because i'm a new member. If you wrote me i would be very grateful!
Thanks a lot
Reactions: maxolini
