So i impulse bought a sub. What would you do with it?
Bandpass orders arent defined by impedance spikes. They are defined by rolloff and # of acoustic chambers.
But This is a quarter wave resonator with multiple resonances that don’t require individual Helmholtz shapes(chamber/vent) to create ?
It’s the impedance dips that define the pressure of resonance on the driver, not the spikes
(Please correct me if I’m wrong, which happens quite often) but there are no ‘odd’ numbered acoustical orders unless it’s electronically manipulated?
Reactions: BP1Fanatic
I'm with Max, it's a series 6th order. You need 3 chambers for an 8th order and the 4th impedance spike needs to be more pronounced like the other 3 spikes and PROBABLY be below 100hz. As you can see below, all the tuning frequencies are below 100hz...tru SUBwoofer.
You know the answer; and this is why any time you replace a chamber with a pipe or horn you reject less of the higher frequencies. Because they are reflected by the nearest wall. Now go back to your cookbook and look at the filter slope refrences. You can see that one is higher order than the other. This makes an odd order bandpass. Even order bandpass matches relatively well both hp and lp. The higher the order the more hp rejection and resonant amplification. Chamber numbers are kind of arbitrary but not nearly as arbitrary as impedance.
Physically, the differences closely resemble a crossover circuit. Chamber is represented as capacitance, ports are represented as inductors. Interference of two or more radiation points outside of the enclosure also represents another order. technically you should be able to add these components to calculate bandpass order. I don't think it's that simple because then the enclosure I modeled in bp8s becomes a bp4 and a th becomes a second order. I think it's easier to look at the enclosure AND the response to determine what it is. Because really, when I use a 4th order crossover, I don't check the components of the circuit, I just look at the rolloff and see if it's 24db higher at double the frequency.
