So i impulse bought a sub. What would you do with it?
Glaxar,
I have ,4 ,15sw2000's still waiting for a cabinet.
Personal issues made me to pause all projects.
Is it ok to store the drivers in their box as it came? Magnet facing the floor of the box, cone looking at the ceiling.
Or you need to orient them vertical so magnet is on left and come facing right
Can I share pics and info on this to friends in a Facebook group/chat/forum about TLs etc ?
(I don’t know your name to give credit )
No credit necesarry. I posted it so its free game. Thank you for the consideration!
So this is a 6th order bandpass
Yes. The only issue i saw with the design was size. These drivers preferred a larger throat volume for some reason, but it seemed to model well if you have the space!
The PRV 15sw2000 has ~169 grams (nearly 6 ounces) of mechanical mass (Mms) pulling the cone down.
I've seen drivers with a fraction of that mass sag several millimeters over time.
After the sag takes a set, the driver's Xmax is reduced, and the offset increases distortion when you get around to using them.
For long term storage, much better to avoid cone sag by storing them vertically.
They were likely stored that way in a warehouse somewhere.
Hopefully not long enough for the inevitable sag to affect performance.
Most drivers are shipped soon after they are built, few manufacturers can afford to store much inventory.
Art
Hey glaxzar,
Are you planning to roll out the PA version of your sub, Fb of 30 or 35 maybe,if I can use the 15sw2000
i dont really have any intentions but if you want something specific i can come up with something
A 42"W x 18"H x 26"D enclosure would probably give me around a 30-80hz response.
18" height would be difficult in this configuration. Everything ive come up with so far is 20" or more. Even if it could cram in there im not sure how it would perform in a trunk. I would consider a 10 or possibly a 12 for this style of enclosure.
Reactions: maxolini
I think the ‘Weaker’ the motor (higher Qes) the bigger the resonator needs to be or it can’t stir up the Fb much. At some point it needs to be a huge TL and then it flops around when not held by the pressure of resonance and really sounds like 💩 (and those need big vented reflex or possible a sealed box to tame?)
When is this just polishing a turd? At some point, you can’t listen to this junk. So creating those huge resonance spikes at three times the fundamental and then trying to remove them electronically is a joke? Right?
I can’t stand this stuff in my ‘experiments’ and it sounds ‘worse’ than brief moments of ringing ?
No, that’s blasphemy 😝
I’m using tapered pipes(as shown) , but have had some surprisingly good results from a 3:1 Parallel pipe (with an absorber stub) more recently
My ‘roar’ has way more group delay than that simulation bp1 created
I don’t know how much is too much
Reactions: BP1Fanatic
tapped horns and bp enclosures have increased group delay. i'm not sure why you're so sensitive to it. what you're showing there is within reason imo. have you checked the enclosure for other resonances or leaks? have you done proper eq and time alignment? most of these advanced designs, tapped horns, multiple entry horns etc, basically require dsp. the idea is that youre going to make compromises that are within reason and are able to be remedied on the digital end in order to GAIN something that you can only get at the end of the chain.
