Hybrid ZEN Amplifier + LM317 = Efficient and simple
IRF630 case temperature measured with infrared thermometer is about 48 degrees after half an hour at max power. IRFP 044 case temp under same conditions has reached about 55. Does not make much sense but this is what the thermo says.
such a difference - maybe HF oscillation (can be in the range above what a scope sees)? Try a larger stopper and one without/with less inductance . . .
Reactions: radumar1
Some Arta measurements: at lowest power, amp has 0.078 THD, almost all H2. At max power, 3.2W RMS, distortion is 1.8%.
Overall I am very happy with this amplifier's performance (meaning sound), as H2 distortion 'rules' across the whole spectrum.
P.s- My Wien bridge signal generator alone has 0.0028 % THD and outputs 1100 Hz.
Thank you Diego !
Reactions: diegomj1973
