SylphAudio New DIY Modules
Is the SE800 based on an IRS chip?
Yes, basically an IRS chip + IRFB4227 with added post-filter feedback.
The sound quality is comparable to amps with 90dB SINAD at 5W 4Ω, but with way more power.
Attached is the FFT with OPA1612 as the control stage. Harmonics are under -100dB. Non-harmonic artifacts come from the switching supply.
  • SE800 User Guide.pdf
Impressive. IRS2092(S) or something newer? I don't think I ever heard about PFFB with IRS2092. What kind of
Impressive. IRS2092(S) or something newer? I don't think I ever heard about PFFB with IRS2092. What kind of Op Amp did you use for the first post? I am surprised that OPA1612 resulted in that much of an improvement (HD2 from -96 to -104 dB).
Yes, IRS2092S so this is intended as a pro-amp/subwoofer amp replacement.
First post is OPA1656. There is a lot of gain in that stage, so the OPA1612 excels in it.
Here are the prototype measurements.
There is SystemD LiteAmp, but this one is implemented differently.
But why reduced gain? No one will buy it for max fidelity purposes. And to use the full power, your source would have to be... not doing the math right now but you should consider the variety of AV receivers, sub processors, etc. that this application might actually include.
Or do you think this will be for pro audio?
For FB100 and FB360, removing the 22uF electro cap before the LM7812 reg going to TPA325x improves the sound. Verified 5W/4R FFT and 7812 output on scope and it's the same before and after. Same 22uF caps on ADJ of 317/337 regs can be removed without affecting the SINAD performance. Perfect warm neutral sound if those 3 caps were removed.
