The Journey of DIY No-Feedback Class D Amplifier (1) Subtitle: The Motivation and Story Behind It
Design a new Monoblock case, the size is 176mm(W) x 278mm(D) x 108mm(H).
Due to lifespan management, the factory recommends replacing the EPC2001C with the EPC2204. The new EPC2204 offers lower Rds(on), Qg, Qgs, and Qoss, (please referring to the attached figure for more detail) resulting in faster switching and reduced switching losses (expecting 🙂 ).
With these improved parameters, the new FET opens up more design possibilities:
  1. Maintain the same power supply voltage and switching frequency, reducing idle power consumption by approximately 20%.
  2. Maintain the same idle power and switching frequency, increasing the power supply voltage by 20% to 58V, which raises the maximum RMS output power to 150W at an 8-ohm load.
  3. Maintain the same power supply voltage and idle power, increasing the switching frequency to 3.8MHz.
These figures are estimates and not guaranteed at this stage. I’d love to hear your thoughts—especially from those on the buying list.
Thanks!
I recently acquired a 24-bit audio analyzer and used it to measure the headphone amplifier. Unfortunately, the AMP module is currently borrowed by a friend. I will share the measurement results once it is returned.
Here is a quick summary, please see the detail in the attached file if you interested.
  • A-weight background noise is about 17uV.
  • background noise is about 23uV.
  • the average THD+N is around 0.002x%-0.003x%.
