Maybe a different measurement technique would offer a better means of separating these things, I don't know. LIMP has also an option of a stepped sine.
Interestingly, the LIMP manual mentions microphony quite a lot. But only as someting that's bothering the measurement.
Hola
I would like to print the WG for Peerless DFM-2535R00-08, and there is WG optimized for the same driver https://cults3d.com/en/3d-model/various/ath-a460-stl-kit, but it is made as complete device without separate throat extension. As I wuould like to have options to change the driver and replace only the extension if needed, is it there any combination of main body and throat extension designed for Peerless 2535
Sure, the DFM-2535 can be used with any Gen2 horn and it has been measured with A520G2 with several adapters:
https://www.at-horns.eu/gen2m.html#DFM2535-STD-3
As I already have all the round G2 horns at hand, I'm going to test the other two (400 and 460) with this driver as well. I would suggest to wait for that, it won't take me long.
The "A460" (non-G2, without an adapter) was optimized from scratch for this very driver and it's a little bit less beaming in the top octave as a result. Otherwise it's very similar to the Gen2 version(s).
Maybe I am splitting the hair here but, are those adapters angle optimized for mentioned 2535?
What about driver exit insert?
T520-25-STD-3 is the closest, basically a matching one (22°), it gives the smoothest response.
No insert plug at the moment.
Thanks Marcel
As I understand there is complete script in the kit so I can play with it and try different parameters/
Yes, the original Ath scripts are in the Cults packages for the A***G2 horns. It gives you a pretty good starting point for anything else. It uses some undocumented features that I should document somewhere, I guess, but so far there hasn't been much feedback.
On the Synergy horns Tom Danley used a small inductor in parallel to the compression driver to "stiffen" them up. Being that close to a multitude of injected sound sources inside the horn I guess you have to. @mabat : maybe you could try measuring the impedance with an inductor in parallel?
I will try this myself but do not have access to the system for a couple of days. No idea what constitutes a "small inductor" in this context though.
How exactly do you wire a compression driver as a microphone to record the picked-up signal?
A cool thing about two-section coaxial compression drivers, is how you can use one section as a regular driver, and the other section as a microphone.
Pop a Dirac pulse through the driver section...and measure an impulse showing the first pulse peak from the path inside the CD, along with the impulse tail showing outside reflections back into the throat/mic section..
The black line is a cushion held over the mouth. It seems smoother to me, which is again indication that all the wiggles are just a reflected sound back down the horn.
Finally something a coax is actually good for 😀... you can use one section as a regular driver, and the other section as a microphone.
That seems like a nice trick when you think about it.On the Synergy horns Tom Danley used a small inductor in parallel to the compression driver to "stiffen" them up.
I would think that it should short the driver below its passband.No idea what constitutes a "small inductor" in this context though.
I'm not into passive crossovers (or even trying to understand them Lol), but it seems that without an amp connected directly to the CD, a low frequency short across the CD might be very much needed.That seems like a nice trick when you think about it.
I'm always amazed how much mid/low cone sections' measurements change on a MEH, when comparing a CD shorted or connected to active amp, vs left open.
Try the stepped sine if LIMP supports it . . .This is A400G2+DH450 as shown yesterday. It uses also a moderately long throat.
And now imagine that the L and R channels "modulate" each other via the room.
But perhaps the delays involved are so big that it doesn't really matter, I don't know. Can we rule out it's even beneficial? 🙂
One could measure the CD as mic when sub or other speakers play; inverse this measurements and use them as FIR to correct theese disturbances (needs of course parallel feed of the "other speakers" signal).
I would say: let us challenge this topic after all others are solved ;-)
That's what I'm doing 🙂I would say: let us challenge this topic after all others are solved ;-)
- Acoustic Horn Design – The Easy Way (Ath4)
