Best 300B SE OPT?
I have a Monoliith on my GM70 and Intact Audio on the 300b amp.
I have tried many transformers on both amps, I prefer the Intact Audio on 300b amp and monolith on GM70
They are silky smooth compared to commodity grade transformers
Only EI ))) at the layout stage
Gabevee -
It looks like Antique Electronic Supply is these days only selling the One Electron chokes and power transformers, not the output transformers. I nabbed a couple of the output transformers while they still had them (I forget which flavor I nabbed, whether the 3k or the 5k). I also have a pair of Hashimoto OPTs that would probably be nice to try.
Correction - Antique Electronic only has the plate chokes, and they are on back order....
Decided Muse Coils latest offerings were well worth buying .
Mine are designed with their trademark Single Cut C core HiB and double coil layout a personal favourite and wooden plinth top and bottom .
These are 3.5K and 4.5K with an ultra linear tap at %40 .
Ostensively for a KT66/88 Single Ended Ultra Linear operation 7- 8 watts max , but can be used 3.5K - 2A3 /3.5 watts, 300B /8 watts max or a 45 / 4.5K 1.6 watts
They are voiced individually and mine follow the slightly darker tone of Tamura but with the added benefit of bass flat to 20Hz conservatively rated .
Each pair come with full test charts / frequency response measured
The workmanship is excellent and when the first amp is up and running will post more , they are likely to be very high performers !!
https://musecoils.com/?bot_test=1
Hi Audiowize,
I will have to ask the manufacturer first and tektronix gear I use will be in an active amplifier test.
The test data is the most expansive I have yet received from any company so far .
As this thread is primarily for SE300B tubes that will be after the KT88 as a build for me .
The 300B distorts quite heavily over 5-6 watts capacitor coupled ,so I normally limit the amplifier to 6 watts unless its DC coupled
Obviously the driver circuit is very important and will likely use a E280F or C3g in triode mode , a 6E5P in triode is also very clean .
and typically that's a monstrous red flag.
Hi
I am totally agree; it is always a problem to get the right data and some real test.
I suppose that to put on desk the right instruments to have a clear idea on performances is not cheaper.
This offline, only trafo, or online, with tube.
One example about test
Walter
Reactions: fortyfive
the link
Walter
Latest data after being wound exact primary x2 - measured output @ 3.32K - 15Hz-50kHz -1dB @ 16 ohm loaded and now wound to 4.6K primary - 15Hz -52kHz @ 16 ohm loaded
