First Watt SIT5
I may have to retract my observation. Re-reading it, it can be interpreted that the P Mosfet is contributing 20% of output.
The sentence reminds me of a phrase that my father enjoyed repeating occasionally to point out how word arrangements matter.
It was "Throw the cow over the fence some hay."
Hello generg,
perhaps you could try to put the output between the first upper and second ( or the second and the third resistor?
Only a thought. Remember the 50W SE Schade -amp arrangement.
And I would think of an autobias -arrangement with 4N35 in the outputstage.
But this is my phantasy...
Greets
Dirk
typically about 20%
Judging by this sounds like the power resistors on the puck pcb are degen resistors(to be able to lower mosfet gm) and the power resistors on the sit pcb are current sense resistors placed in the drain of the sit. The sit behaves better without degen at high power levels and low impedance loads.
You can look in the sim how much current each transistor contributes and adjust the mos degen resistor accordingly.
Reactions: Chuck NoCal
Hi Dirk, I tried the different resistor connections, no real game changer.
I have the feeling this time there is no 4N35....
I stop here and wait for better men! With more experience in electronics and LTspice.
Whoa! This is the big one! Front end is very intriguing. Input cascode into unobtanium Toshiba FETs. That must sound quite special. Sure Papa sprinkled in some magic dust to optimize it and used the best parts possible from his mega stash to drive the SITs because of course they want the best. Four years in the making means it really is getting the most out of the SITs. It sounds like a giant killer and we’ll all want to build one 🙂
Merry Christmas all!
Yes.. Merry Christmas to all.
And a question. I see the 252SIT has a similar output? Or I'm I looking at this wrong?
I'm still hoping for a stable 50wpc into a 4 ohm SIT amp. Of ALL the amps I've ever had, and listened to, the 252SIT was the most transparent... it never sounded loud. It just played as a true wire with gain... until, well, Smoke On The Water, And Silence On The Sky... 😛
Still have six SIT transistors waiting for the day... I mean I could possibly use two bridged F4s and BA3 (or YIWDAF4), a Sissy SIT and the power resistors.... nothing like using a kilowatt of heat to get 100 watts... Cables, lights, boxes, switches....
$10K... gulp. That's approaching Pass Labs territories. Hopefully the stock market will move higher next year....
Seems pretty clear from the sketch, voltage gain from the front end, SIT is just a MU-follower, no gain, Nelson mention an easy 40W with this circuit at the SIT section. Seems to match the published pictures rather well…
Also the sketch shows that the feedback is limited to the front end section, and doesn’t include the MU follower SIT final section.
SB
without third ( 4th, 5th..) confirmation source, I'm not eager to draw conclusions between simplified schm above, and fact that FW Products page is stating SIT 5 as No Nfb gadget
though, output impedance and THD figure are sorta confirming No Nfb scenario
That's Pa
:clown:
anyhow - all guidances are there, World is our Oyster (again)
now, just make it not using scarce Toshiba TO92 and Toshiba small mosfets .......... and job's done
ambitious ones can even skip SIT, using Schaded N channel puck
:rofl:
