JLH Class A headphone amplifier
Always start to populate pcb from smaller/lower components (resistors, IC) to bigger (electrolytic capacitor, radiators, etc.)
Hello .. yep I know that 👍 as I have enough building experience to construct in any method or order of procedure that I feel like
But for me building electronic circuits since the age of 15 I am confident to make how I like in my workshop and what ever takes my fancy on the day etc
But do agree this is the best advice and best practice 🙂
But in my work shop I have no rules .. except good practice for safety etc
and SMD is banned or kept at a minimum if I can help it
all the best 🙂
Hello Kuzmenko
As said you are correct in your post .. as I get older you sometimes slip into bad habits
My next build will use the lowest Hight components 1st .... then on to the highest .. agree this is the best practice
all the best
anyway some of my other construction skills .. purely done by feel and the good old fashion eye ball
A EL34 valve power amp one channel shown as they are mono-blocks
1st 15w in pure class A
Reactions: decramer
few more pics of my progress for the JLH class A headphone Amplifier
Reactions: decramer
and the B184B and 2 power transistors with heatsinks fully mounted (all matched) just waiting for some more components to arrive from RS and Rapid .. plus mouser etc
Hello gang
headphone amp nearly complete .. quick update on the main headphone amp
Reactions: davym
I still have my original Chiara headphone amp /preamp. I built mine when the kit was first published. I used original PCB from JLH kit. The 2 cases on the top shelf are JLH Chiara Headphone / preamp and power supply installed in my DIY cases.. The two items below it are a pair of ESP Audio P3A power amp mono blocks again in my DIY cases. I am a retired Electrical technician I used to work at a very large Pharmaceutical site in UK. All the enclosure heatsinks were made using materials from scrap Motor Drive VSD cabinets the rest of the aluminium came from scrap production machinary.
Hello penn07
Many thanks for posting .. great post this is exactly how I make my amps, always trying to reuse big heatsinks from old equipment
I love the Chiara its a great headphone amplifier that is why I invested lots of man hours to reproduce the pcbs's etc with new gerber files
would love some internal pics if possible
all the best 🙂
Hi James, I managed to end up with your original build of the JLH HP amp. Excellent build and still going strong!
Out of interest, have you ever tried upgrading the regulators? Do you know what current is going through them?
Hello
I tried all sorts of regulators and to be honest did not make any real difference .. not that I could hear anyway
The main heart of the design apart from being simple and a single ended Class A design was the op amp that I used ... which was the BurBrown OPA627
