AckoDAC based on ES9039PRO
Stereo and mono boards …
Reactions: Stepping3D
MCH is a great choice. I can show you how to connect up to this DAC to get the best out of it 😊
By the way, does MCHstreamer work with linux(alsa) ? Anyone tried?
Acko, if you have time and mood)) to share, did you use it wih your dac as master? How you overcome the shortcomings? Does Ian`s FIFO solve it completely? By the way, FIFO better to be clocked from DAC clock, or vice versa (in case of clock board added to FIFO) ?
MCH can work with Linux as advised by MiniDSP but not tested yet.
DAC has flexible interface for both Clocks and Inputs. McFiFO compatible… More details later🙂
Reactions: Charcoal
Note: the balanced outputs of these DACs are gain-staged to ~10V rms. This means they can directly drive popular balanced Amps e.g. Class D types (TPA3255, Hypex, Purifi, NCore etc) close to full output with better SNR.
Other DACs, mostly around 4-5V rms balanced output so not optimally matched levels …
Reactions: Gill.T and Charcoal
Reactions: Gill.T
