Amplifier suggestion for old 3w speaker
Nicely made fuse box. The secret to doing it is to spend the $25 to put in two separate ground bars, one for each side, as strap them together with a piece of #4 Cu (the big fat green wire running across the top.
Reactions: diy1995
The time spent assembling was negligible compared to designing, tweaking, adjusting, and verifying each functional block. It might sit for a week while I wrestle with the latest issue on paper before picking up a soldering iron again. I wanted all that wrung out completely before committing to a final design, since all the protection circuits that were being developed went into multiple amp designs. As soon as I get the shop and house built that “warehouse full of projects” is fixing to turn into several racks full of Iron Pigs. They don’t make them anymore, but I will. The core amplifier design was perfected back in 2012. That’s how far back that rabbit hole goes. When someone says he has to put a project on hold because of life, I completely understand and can easily relate.
Reactions: diy1995
What’s hilarious about this, is that the polarity is the same. From left to right, highest potential, lowest potential, finally the one in between.
ICs are designed with the lowest potential (most negative) in the circuit connected to substrate, which soldered to the center pin of a TO-220 lead frame. Can’t really blame the designers…..
Reactions: diy1995
4440 board, 2 channel is like 200 Rupees here.($3)
6283 board, 40 Rupees. (50 cents)
TDA 2030 board, 70 Rupees. (90 cents).
TDA 2030, two channel, good caps, about Rupees 250, $3.
There are 2.1 drive boards as well, third chip amp for driving a sub-woofer.
If you think it is worth it, just buy the ready populated boards, some even have a heat sink, saves a lot of time sourcing parts and assembling board.
True true, thats what I missed.
That would be more economic, but I like to do my circuits and learn in the progress. Also 1/2 of my project is custom, cannot be ordered on premade pcbs.
