'ceci est un Cube' amplifier from JM Plantefeve
What is the bias current you recommend for the Cube X ECW20n20/20p20. I read that you gave 140mA bias to the K1058/j162. thanks
@grunf What JFET-s are you using in your final design? I noticed, that you also tried JFE2140. How would you compare it to with IF170?
I have experienced sound quality loss with chinese 23 Step Attenuator using Vishay Dale resistors. Do you have a better plan or option how to still have the Hi-Fidelity and to change the volume besides Alps RK27 pot?
Also looking for regulator schematics. 😉
I was wondering whether I could raise idle current of the output transistors to, say 0,7A, in order to get into Class A operation, lowering the PS voltage. I really like this design of using two 2SK170 JFETs (I happen to have plenty of them, all genuine purchased back in the late 1990s), instead of the complementary pair with 2SJ74 (of which I have not as much). But I always preferred playing in Class A and, as I understand, the Cube operates in Class AB. Of course, I haven't listened to it to judge - just saying...
You can essentially take any fully complementary circuit and replace the 2SJ74 with a 2SK170, wired as constant current source.
This is the case here, but you can see the same in Wayne's line stage at the Pass forum.
You loose half the open loop gain (input stage no longer push pull).
So if nothing changes, distortion goes up by 6dB, mostly H2.
If you want to use a pair of K170s for Class A power amp, you should look at the many Kaneda designs on the net.
At least that's what I would do.
https://www.diyaudio.com/community/threads/narsis-kaneda-mosfet-amp-built.416094/
https://solidstate.exblog.jp/1809626/
https://www.diyaudio.com/community/...-described-by-paul-kemble.220923/post-7797133
Patrick
IF170A is in my final design. The JFE2140 is not in the same Ids range so I didn't even consider it in this case. He is currently only on paper in the amplifier from post 17.
As for the pot, I think the Alps RK27 is quite a good choice. I have a P&G in Le Monstre, which in my opinion is the best I've tried, but the downside is that it's a slide pot and 120mm long because it's intended for studio mixers and consoles. I would certainly avoid those chinese steppers with questionable resistors.
It's not a problem to push it into A class, I have a quiescent current trimmer on my PCB and the power supply is dimensioned that way, but the current heatsink does not allow experiments with higher currents.
This amplifier is a complete surprise to me, but only with the regulators, which is obvious because of the simple design. My Le Monstre hasn't been played for more than three months, and I have to admit that I pushed through the summer heat more easily.
Dear grunf,
A couple of questions regarding this project.
From post #21:
Adjusting the offset and quiescent current is not complicated and does not take long. Quiescent current is not adjusted in the original scheme, but I added that option mostly because I want to do some experiments with the replacement of transistors.
and in post #90:
As I understand, you have followed ZoltanChivay's circuitry shown in post #8. This has 2 trimmers:
R16 - DC regulation at the output
R15 - bias
In your implementations, I notice that you use 3 trimpots. I assume that the third is used to set the quiescent current, as you say that you have added that option. Forgive my ignorance, but doesn't the bias setting regulates the quiescent current? I'm a little confused here. Could you please show a schematic of the circuit that you actually built? I'm considering building this amp and I too would like to experiment with higher quiescent currents.
Thank you,
Evangelos
