Zenductor 2 Amp Camp '24 version
So, if I up the power supply to 18V... and add taller heat sinks... other than the LED being bright... I'm I safe setting the bias at 1.5V?
I don't see many power supplies at 16V, but quite a few for 18V... It would allow me to put a single Mean Well power supply in the box.
What would the power be?
Assuming the gain is the same, mostly what I'd be looking at is higher peak power, is that it? Could I get 15 wpc?
Mostly, I'm not after more power, but just finding a single power supply that I can fit in the box. In reality, 10wpc is more than I need for this application.
Regarding heat sinks and cooling: It seems from Nelson's and other measurements that the heat sinks as is are dispersing ~12 W (16 V * 1.5A / 2 heatsinks) each at a Delta T of 50°C (or K) (75°C heatsink temp minus 25°C room temperature), so about 4K/W or, since they are about 200 cm^2 or 0.02m^2 (from my measurement of the fin lengths), about 12 W/m^2/K without any forced air flow.
Looking at
with a small fan and air at a few m/s you are not going to gain a factor 5, but more like a factor 2. But that still gets you a significant gain (factor 5?) in transistor lifetime, and also brings the heatsink temperature below the pain threshold, to maybe 50°C.
This also seems to be roughly in agreement with this graph
from the heatsink datasheet, at the Mouser link @birdbox provided, where 12 W corresponds to a Delta T of ~45°C (rising dashed curve and lower and left scales), and 200 ft/minute = 1 m/s air speed gets you 2.5°C/W (falling dashed curve and upper and right scales), so 30°C above ambient, or 55°C total, for 12 W.
Reactions: birdbox
TLDR for my last post (the edit interval on this forum is too short): a small fan or double stacking the heat sinks should get you into the 'safe to touch' regime, and significantly extend the lifetime of the output transistors.
If you put the amps in a case, and the metal side walls are larger than 8" by 4" (200 cm^2 single surface area), you automatically gain a factor two in heat dissipation by bolting the transistors to the walls.
I'm not an electronics designer, but I think running parts at 80°C surface temperature is ok if you are not expecting half a century of lifetime. And actually it still might last half a century.
Regarding safety: people (including me) run tube amps with exposed tubes at significantly higher temperatures. Candles, stoves and fire places are also a lot hotter, but might give you more of a visual warning. Maybe put 'Caution Hot' stickers on the heat sinks?
Also, as Nelson pointed out, maybe you actually want to run at lower bias current and higher 2nd order harmonics?!
I really like the design; remember that part of the design idea (as I understand it) is simplicity and reduction to the essential.
The heat sinks on this amp is looking lot smaller than aca amp. But both amps have similar output mosfets and bias currents .. so do we need to use bigger heatsinks here , at least of the sizes used for aca amp
The heat sinks used on Zenductor II are the same size as the ACA Mini. In fact, it's the very same part as far as I can tell.
If you have little kids and want to keep the temps down a little, I don't think there's anything wrong with stacking on a little more heat sink instead of backing off on the bias for risk mitigation.
ACA Mini on left, Zenductor II on right.
Reactions: Gruesome
Yep, that's a very fair point Mark. I missed that and removed that comment above. I don't see what the issue of stacking a little extra is though. Is that a bad thing to do? I got the impression it should not change anything sound wise. Is the smarter option to just back off on the bias?
