Hornresp
Either some more advanced simulation (abec, akabak ...) or you just build it, maybe just a rough test enclosure.
It matters a lot less than you are worrying about. Take a center path measurement around the bend. If you are looking for a trap effect for the midrange being sent down into the Transmission line consider making a coupled cavity immediately behind the driver with some fibrous tangle to absorb it. Rockwool is a superb broadband absorber and I specify it in many designs. Works wonderfully.
Thank you guys, you are right. I need to leave analysis paralysis and finaly build something.
I will probably do few more simulations, to guestimate the bend better.
Idea of prototype is good => this will allow me to fine tune both segment lenght and damping.
since the manufactures i found provide no data for acoustic-phase and electric-phase(and sadly also no Vas so i have to guess), i'd like to predict that with hornresp to have data for Xsim.
Is that possible for a cone-tweeter like https://www.visaton.de/en/products/drivers/cone-tweeters/tw-70-8-ohm or a dome tweeter?
I guess these a in essence closed box designs, but maybe the values are to small to predict something useful?
Visaton has it's own simulation tool (Boxsim) with data of all visaton drivers. I can post an image or maybe even try to export responses, not sure whether boxsim allows that.
Edit: you can also derive phase from the SPL and impedance frequency responses. But you cannot acount for acoustic center deviation of spl response phase, afaik.
By chance Is there a way to create a 4th order BP with a passive radiator instead of a vent?
See the Fourth Order Band Pass Enclosure section in the Help file for details.
Reactions: Booger weldz
Reactions: rertrobaer
Does the update resolve the "exp" problem you were experiencing?
Probably related, i'm using HR via wine on linux. When i use the input wizard, the angle shows a lower case "pi":
When changing it via clicking on it, it's upper case again:
Another question about semi induction:
I used VituixCad to get the semi induction parameters. VituxCad has only one parameter for Re and Le, so i
assume that also HR ignores Re and Le from the normal driver data, and only uses(if "green"/activated) Re' and Le from the semi-induction parameters instead.
Is that correct?
Can i derive FDD parameters from this data? I can't use the Excel file as i have no Windows-Word and Libreoffice can't handle the macros.
It is definitely related - see the image below.
I noticed the lowercase e in Exp but completely missed seeing the lowercase p in Pi. Hopefully it should be possible to work around the problem the same way as was done for exp. I will have a look when I get a chance.
i assume that also HR ignores Re and Le from the normal driver data, and only uses(if "green"/activated) Re' and Le from the semi-induction parameters instead.
Is that correct?
Correct.
I'm not sure what Excel file you are referring to. As far as I know the values for Frequency-Dependent Damping parameters Rms and Ams would need to be provided by the manufacturer as part of the driver specification.
Thanks David for the info, the excel i was referring to is here https://www.diyaudio.com/community/...rporating-semi-inductance.329096/post-5964729 , it seems only scan-speak provides Ams info, or it has to be measured via added mass.
Another question about bp4 and strouhal number, this is not shown in the bp4 -> "port velocity" chart neither by pressing L or ctrl-double-klick.
I didn't find it in the help-ile to be excluded for bp4.
Is it still applicable in this case to calculate the number manually?
St = a / ( u / ( 2 * pi * f ))
Confirmed blow-up right at Continue button (after all selections are made) & lowercase (and I bet my Wine 5.0 is considerably older than @retrobaer's).
The good news is that the record stays created in the .dat file so I'm completely good with it as is 🙂 Thanks again for the amazing tool and all the hard work, David!
Reactions: Kravchenko_Audio
Is it possible to make a simulations for this type of enclosure:
Hi Roman,
Specify two stepped segments as shown in Attachment 1. Segment 1 represents the enclosure and the segment 2 represents the damped port. Use the Loudspeaker Wizard to add absorbent filling material to segment 2 as shown in Attachment 2.
Kind regards,
David
  • Thank You
Reactions: RomanMarts and stv
