Acoustic Horn Design – The Easy Way (Ath4)
Thanks!
I'm adding a mount to the adapter, this is the simplest one I came up with. I'll here by call it the t-mount 😀
I suppose it's not constant until the snakes are equally fat from 800-20k 🙂
I'm not a magician 🙂
800-20k would need a 575mm waveguide with 19mm throat. Possible with the right driver, I guess. Worth going that far? I'm not so sure.
A460F would be for 1" or 1.4" driver?
This is 1".
- Even now it's not perfectly flat, but close:
Reactions: decramer and DCDK
Picky... yes - but I suppose correct!?
I could be wrong, but I'm fairly certain that flat normalized frequency response at all angles in free space is a physical impossibility with any real waveguide due to diffraction at the mouth (unavoidable as the termination must be finite). Practically speaking, constant directivity means a flat or nearly flat DI with reasonably flat individual responses out to at least the effective coverage angle.
Almost done (a new, true constant-directivity waveguide)...
View attachment 1367095View attachment 1367092
I only need to think through the kit.
BTW, this is the current Gen2 approach:
cool, do you have a plan for it, like whether something like this becomes available for 1.4" drivers, perhaps the whole gamut of adapters like the ND3x? And what kind of a schedule you have with this project, released roughly within a month or perhaps later?
Really? 🙂
It would definitely mean a ring plug and a suitable compression driver (which even reaches that high), maybe with an extended throat. And would very probably end up with DSP as necessity.
If a suitable compression driver exists, it would sounds like a fun project. Otherwise I go for the already purchased 520G2. I want to use anyway a miniDSP FLEX as a crossover, so DSP is not an issue. Bass driver will (probably) be a SB Acoustics SB34NRXL75-8 in a sealed enclosure.
