18sound 21LW1400 enclosure
(My junk I had handy to measure)
Parallel qw pipes (top)
parallel Helmholtz (bottom)
pipes sure store a lot of energy and ring? 3x Fb is wankered.
@BP1Fanatic , do you not experience something similar in your tapped pipe? I need to measure one of mine that are tapered like yours and compare
What I had hoped, was that we (you and I) could figure out how our tapered pipe shapes and XO points(or dsp) were helping to minimize the issues in the variety of pipes we have designed, simmed and built.
but, as usual, you’re too busy cheerleading and chanting ‘BP for life’ to even participate in anything subjective or relevant to what actually happens at 90hz (or any 3x Fb frequency) in OUR tapered pipes.
You are repeatingly suggesting an 80hz XO is preventing the 90hz resonance from existing, or are you saying it doesn’t matter because your musical tastes are complimented by a random pipe resonance ?
Neither would particularly make sense to anyone, it has nothing to do with ‘audiophiles, I thought this was simply physics of sound in pipes?
There is nothing to study.
YOUR link told US to filter TH's and QW's below 100hz.
I try to design my enclosures to peak at 80hz so whatever happens at 90hz is a non-issue.
I'm making sure everyone knows I'm not trying to create an audiophile (>50hz) enclosure unless specified by request like freddi.
What kind of low-pass are you using? How steep and where?
I ask because fi the examples in #81 are typical of the above band resonances in your builds, those take at least a 48dB/oct low pass at 90Hz or less, and could still benefit from a sharp notch around 120-125Hz.
(Some incredibly strong resonances! I'd slap a 96 dB/oct linear phase low pass at 90Hz on them.)
Reactions: maxolini
See post #105.
HR can't sim well paraflex designs , as far as I know , those designs truly were refined the old fashion way before computers , doing prototypes ... measure...prototype ..measure ....wash .rinse..repeat
Not to my recollection, and I've been following Paraflex designs from since inception. HR sims were involved almost from the very beginning. The problem is that when I started to create my BOXPLAN workbooks for them, I noticed some mistakes in the sims, and suggested corrections. Build what you sim / sim what you build, and the measured results should be fairly close to the sim'd results. Hornresp does not include the effect of box losses in Paraflex sims, so you're going to lose a little output in the higher resonance spots in the passband.
Reactions: maxolini
