A boring 2 way build
Welcome to a super boring 2 way build
Well.... I have these Silver flutes laying around and decided to make a cheapo 2 way with them. They were originally meant for my car but wouldn't fit. Then I was going to throw them in the wife's car but.... also will not fit.
So screw it! Lets throw some more money into the pit in the form of a tweeter and some crossover components and see what happens.
I picked this Peerless tweeter to go with it. The built in waveguide lets me cross it quite low. Under 2k. This should, in theory, sound better that crossing it over inbetween 2-5k which, I am told, is not the best place to cross drivers since hearing is sensitive there. The waveguide puts the z offset of the tweeter mechanically close to the z offset of the woofer. I am going to test this to see how close they actually end up.
I'm going to throw a 0.4 cubic foot box at this and vent it. I will post the WinISD sim.
Just thought I'd share. I'll probably use these in my garage since both drivers have really good off axis specs.
Pretty simple, pretty boring, maybe they will sound pretty good.
If I have to yes. I will get a 2 ohm Taramps amplifier. This is a very cheap build.
That crossover is just me messing around. I will probably move the XO higher. We will see when I measure everything what the actual distortion of the drivers comes in as.
A series crossover is more complicated than a standard xo. It is not just wiring the driver's in series. (I have never attempted one.)
However, a standard xo should be fine, you probably just need to refine your initial attempt. Using two 4-ohm drivers should allow you to create a 4-ohm 2-way speaker. The rule of thumb is to not go below 80% of the nominal impedance, so just keep your system impedance above 3.2 ohms.
I am by no means an expert. I merely thought series would help with impedance. The actual crossover details would take a lot of experimentation. I am by sheer luck and trial and error currently using a series crossover in my OB 3-ways. However, I started with concepts from very capable designers and played with Xsim until I found something encroaching on the universe of reasonable. Your attempt looks promising, though the parallel one has much less overlap.
I’m out of my depth on crossover design as soon as I say crossover. :rofl:
I think I can figure it out if I throw some time at it. I have hour and sometime days long lulls at work where I can just throw my engineering time at personal projects
Reactions: von Ah
Here's a paralell and I'm right at 4 ohm. Just had to go 3rd order on the tweeter. Probably best since I'm crossing it so low.
Reactions: ICG
Looks like a good start.
Depending on your answer to AllenB's question...may need to add y-offset.
If you use an air core inductor on the woofer that will add some DCR and i think raise the impedance a bit.
If you need to add a padding resistor to the tweeter, that raise the impedance a bit.
Overall, I doubt a low impedance will be a problem.
Search diyaudio and Tech Talk, maybe MAC, and see if you can find any posts on how low that tweeter can go. I did a quick search on my phone and didn't see anything, but I have those tweeters and looked into it before. I'm thinking 2.5khz but I put very little confidence in that recollection.
Reactions: Turbowatch2
Where's your baffle step compensation????
Sometimes (rarely) woofers have this baked into the response by the manufacturer.
It appears the Silver flute manufacturer measurements are infinite baffle (concurs with Zaphs IB test sample). Therefore you'll likely need to target 87dB system sensitivity. Apply your baffle diffraction response to the manufacturer curve to see what I mean.
Punktkilde drivers seem to have reducing efficiency with increasing frequency. These are IB / IEC measurements I believe. AS you can see the sensitivity reduces with increasing frequency. I'm not saying "no baffle step" - but you have to understand the measurement conditions of the driver whose FR you are using before you decide how much may be appropriate.
https://www.punktkilde.com/sites/default/files/product/specsheet/W ASDWD0001-0401_0.pdf
Are these your measurements or did you trace the datasheets?
Just traced them. I'll pull measured data once the tweeter arrives. I'll build the box
All of this is theoretical at this point. I'm yet to take the actual measurements
Reactions: Dave Bullet
