DAC AD1862: Almost THT, I2S input, NOS, R-2R
@hirscwi I am not sure but it looks to me that FifoPi with RPi is somewhat universal and can output I2S specified for different DACs and the configuration is in the software (like in Volumio settings) 🙂
Check the settings provided by @zoom777 in his previous post. Select Target big depth = 32 (this should represent 64fs), but try Target sample rate give less, like 96 kHz. It can start play music after correct configuration 😊
Best in the socket from the DAC and OPAMPs and follow the schematic 🙂
DAC: pin 9 or 12 = GND, and voltages are pins 2, 4, 8, 16
OPAMP: pin 3 = GND, voltages are pins 4, 7
Thank you.
No magic smoke and voltages are fine!!!
Can't believe it. My previous venture into DAC building, albeit years ago, did not go well (Subbu DAC).
Now I am a step closer to completion.
Reactions: miro1360
Yes, I suspect you are correct but I have yet to completely understand it. The FifoPi Ma works in master mode (as opposed to sync mode) and I don't fully understand the differences.
BUT, I had a suggestion from member Gizmo3 to add a plug-in to Volumio. It is the Fusion DSP plug-in. The settings used "convolution filters" "disabled effects" and sampling rate of 176,400 ++. It works like a charm but I don't know why. I'll try to learn more from Ian Canada...
Thanks for the continued support. I'm now working with the folded cascode CEN IV as the I/V converter. So far I really like this DAC - will try the AD1865 next...
Thank you.
Weird ! It sounded fine, I had two. One for reference and one I gave the mods here cause it was a little lifeless for my tastes, but that Vref asks the best as te ppower supply and decoupling choice ! My first smd project. A good chip that this ESS9023 ! The only difficulty was it is smd but nothing on the suregery side though, no harder than the shift registers in the ad1862 V1.3 board here !
You certainly learnt more than you think with it whatever the final result.
SPDIF/Optical to I2S, almost THT, WM8804
Repaired (coupling capacitor in the SPDIF input is needed) ... otherwise it is the same as in the post #2139
Sorry for any inconvenience 😱
Components example, mouser:
IC1:238-WM8804GEDS
R7, R8, R9, R10:594-MBB02070C2209FCT
R4:594-MBB02070C7509FCT
R1, R3, R5, R6:594-MBB02070C1002FC1
JP1, JP2, X5:571-5-146284-2
JP3:571-5-146285-3
X4:571-5-146268-4
Q1:520-ECS120-18-4X-CKM
C13, C14:81-RCE5C2A180J0A2H3B
C16, C17:80-C324C104K1G5TA
C1, C3, C5, C7, C9, C10, C11:505-MKP2D031001FJO00
C12:505-MKS21.0/63/5
C15:667-EEU-FR1H100B
C2, C4, C6, C8:667-EEU-FR1E101
TR1:580-786013C
IC2, IC3:511-LF33ABV-DG
X1:651-1729128
X2:GP1FAV50RK0F Original and New SHARP Sensor | eBay
X3:502-PJRAN1X1U02AUX
(JP1, JP2, JP3):855-M7582-05
Any reasonable alternatives for the way back ordered TR1?
Murata Pulse Transformer
Dan
