My wolverine is coming to the end. Still no music test, but with 1khz sine is able to produce around 150W on 8ohm. Transformes are 500w 42vac each. Dc under idle is around 58v going down to 55v at 150w.
During several tests I disconected 240v at around 100w load and one of dc protect board relay has gone. Welded contact probably. Don' engage anymore. Have to dismount some things to check. Don't like this.
Vanilla mechanical relay are not suited for DC protection, when disconnecting a high DC current the contacts will weld. You should upgrade to Solid State Relay consisting of two back to back MOSFET's and a MOSFET-driver, there are several examples on the forum. On the other hand, you could simply avoid having DC errors, this to save the relay. 🙂
Highly recommend @felix1024 speaker protect board if you need something compact with all the options (DC, overload, overtemp, start delay, LED outputs). Also been a great help with me personally. Designed for SMPS but easily adaptable to run with a linear PS if you have a 12VDC aux. supply.
This post here felix1024 speaker protect.
I know that there are a different number of transistors, I just want to know if they differ in terms of sound quality.
No difference in sound quality, the EF3-4 will have better power handling capabilities depending on transistors used and rail voltages.
Really output transistor selection is more about your intended speaker load, power levels, and rail voltages more then anything. Another determining factor is availability and if you are willing to drill new holes in the UMS heatsink for larger outputs, or order the Modushop predrilled heatsinks for the Wolverine.
That being said there is a difference running the 2SC/2SA series vs the MJE series, and the corresponding comp. caps and resistors, with the 2SC/2SA series being the preferred choice for sure.
Predrilled heatsink is smart way. Its not just the holes for outputs, board is secured as well. Thats a lot of holes.
It’s a shame they all obsoleteThat being said there is a difference running the 2SC/2SA series vs the MJE series, and the corresponding comp. caps and resistors, with the 2SC/2SA series being the preferred choice for sure.
How and why is the 2SC/2SA series the preferred choice ?2SC/2SA series being the preferred choice for sure.
Yeah I heard you bought up all BDent's stock of 4883A/1859A when they shut down (just kidding 😛), And you do a valuable service to the readers here by offering spares/kits/complete builds. I'm just thinking in 5 or ten years when someone picks up some wolverine PCBs from a garage sale, or if someone just wants to order everything in one go from one shop, the only option is onsemi parts. Except maybe for that one sanken driver...
Im not certain but just looking at the data sheets, the 2SC/2SA parts generally look faster and more linear than the MJE. But data sheets and real life aren't the same thing. Curious if you have measured differences? Distortion, slew rate/bandwidth?
Yeah I wish, to be honest I didnt even know they shut down until recently. I have stock that I have had for awhile, and sourcing stuff still when I can find it, and know its genuine
That’s pretty much what I wanted to find out too, are the 2sa/2SC devices superior to the mje onesCurious if you have measured differences? Distortion said:
Lower distortion, both measured and simmed, as I mentioned this is mostly due to the fact that they allow lower value comp. caps without effecting stability.
- DIY Class A/B Amp The "Wolverine" build thread
