It was worth all the effort to see it 😉Now marvel at this beauty!
Mouth reflection, or diffraction, I still don't know how to call it the most appropriate way (it's always a mix of both, I guess).What aspect creates the dips at 5,5, 11 and 16k?
The termination can't be much more abrupt than that.
- Now the question is whether we could tell the difference in a listening test. We tend to pretend we can, but do we? 🙂
It should subjectively distort like crazy at least at high sound levels. As it's not really that much resonating, the effect on coloring the sound may not be that big. The imaging can be a bit blurred, who knows.
You know what, I'm actually tempted to try it some day, just to hear it (or not).
I know of no other way than transferring the definition from Desmos to Ath (G2 edition) and get the coordinates from there (there is a plenty of options there, one of them is just to use the nodes.txt file).Is there a way to get a spline, bezier, vector etc. out of desmos?
A question: With a high-sensitivity source, such as a compression driver in a horn, to what degree can sound waves incoming from the outside environment into the horn, reaching the diaphragm of the driver (can be the reproduced sound in a room itself), modulate its electrical impedance? Does anyone know? Is there a sensible SPL at which this could become significant?
When measuring electrical impedance of a driver in a horn, it's typically pretty sensitive to the outside noise, and I always think about this. My guess would be that with a passive crossover this could modulate its transfer function (in wild ways).
I don't know the answer to the question, but if the reflection of sound in the horn causes problems, then external sounds of the same intensity should too. On the other hand, the intensity of reflected sound and noise from the room is usually much less than the pressure near the mouth of the waveguide.
By the way, any DIY attempts for the correction of horn reflections with FIR filters like Fulcrum does?
Eliminating Horn Reflections
The resonance in a horn is caused by an acoustical reflection. Now, nothing in the signal can prevent the initial acoustical reflection from occurring. However, the sound energy that was reflected can be prevented from reaching the listener. If, instead of a compression driver, the throat of the horn was coupled to a perfectly absorptive termination (imagine replacing the compression driver with a long tube stuffed with fiberglass), then the reflected wave would be completely absorbed, and the listener would never hear it. Of course, a compression driver is not nearly that absorptive. To be effective at producing high sound pressures, its diaphragm must be very rigid — so most of the energy in the reflected wave reflects off of it and courses back down the horn again.
Here’s where it gets interesting: with DSP we can imitate the condition that would occur if the return wave was completely absorbed. When a wave front encounters a perfectly absorptive termination, a very particular sound pressure occurs at the boundary. When it encounters a reflective termination, like a compression driver, a very different sound pressure occurs at that boundary. If however we supply a delayed and modified version of the original signal to the compression driver, then we can mimic the sound pressure that would occur if the compression driver were absorptive. If we do this precisely enough the compression driver diaphragm will have the same velocity that the air molecules would have had when they encountered an absorptive boundary. The sound pressure at the diaphragm will be the same as it would have been at an absorptive boundary. In fact, to the reflected wave, there is no difference between the compression driver and an absorptive boundary. In both cases, the returned wave is absorbed and the resonance is eliminated.
I'd love to do live double-blind testing on that. I wonder if it would end up sounding unnatural.
I think there have been many DIY attempts (some successful..) incorporating an impulse response inversion to provide the corrections.I don't know the answer to the question, but if the reflection of sound in the horn causes problems, then external sounds of the same intensity should too. On the other hand, the intensity of reflected sound and noise from the room is usually much less than the pressure near the mouth of the waveguide.
The level of granularity used in determining what may be (and how it can be) corrected takes a lot of experience.
Dave Gunness has been at it for over two decades, and mastered it before most DIY were even aware of what FIR was, or could do.
https://www.diyaudio.com/community/threads/preconditioning-fir-filters-how-do-you-make-them.366934/
Although I have not done double-blind testing of "corrected" (EAW called it "Gunness Focussing" before Dave left and they changed the name to EAW Focussing) I could definitely hear a positive difference from "before" Focussing (a system I worked with around 2000) and the same "after" Focussing around 2006.
And the Mackie speakers which had rather so-so horns and drivers which employed "Gunness Focussing" sounded (and measured) far better than prior.
Art
If the electrical impedance of a driver was modulated, it's frequency response would also be modulated, changed.A question: With a high-sensitivity source, such as a compression driver in a horn, to what degree can sound waves incoming from the outside environment into the horn, reaching the diaphragm of the driver (can be the reproduced sound in a room itself), modulate its electrical impedance? Does anyone know? Is there a sensible SPL at which this could become significant?
Multiple entry horns mid or bass drivers can produce SPL greater than 160dB in the throat region of the horn, yet when all the drivers are driven with pink noise the frequency response of the HF driver remains unchanged, the same as at lower levels.
I would not think any "sensible" outside environment SPL levels would be near those SPL levels.
When measuring electrical impedance of a driver it is not controlled (dampened) by a low impedance source like an amplifier provides.When measuring electrical impedance of a driver in a horn, it's typically pretty sensitive to the outside noise, and I always think about this. My guess would be that with a passive crossover this could modulate its transfer function (in wild ways).
A series capacitor can eliminate amplifier damping, outside SPL can modulate the diaphragm.
After shattering dozens of beryllium diaphragm TAD HF drivers actively crossed at ~5kHz (which should have limited excursion) Dave Rat found the "protection" capacitors in series could let them wildly shake at their resonant frequency (hammering the phase plug) while testing the PA with pink noise while the HF was muted.
Removing the series capacitors eliminated that problem, the only failures after were the result of thermal failure.
At high drive levels, the rising temperature of a compression driver's voice coil will increase it's electrical impedance, which can have wild effects on its frequency response using a passive crossover.
Art
I remember hearing about that happening. Wasn't the solution to include at least a tiny inductor across the driver? Not enough mh to form a second order filter against the series cap but just enough to brake movement of the diaphragm from sound in the room? Also didn't a few thou$and worth of drivers get damaged before realizing wth was going on?
I suppose the horn in its reversed view will be a sound sponge... it will like to absorb everything and give back nothing so the membrane in the end will be exposed to a lot of sound energy. I mean, thats how backward horn loading of e.g, nautilus speakers work.. absorb the back wave of the driver- no?
I suppose if they had shorted the CD input terminals during the noise tests, the drivers would have survived - an inductor does about the same thing - a decreasing short as frequency goes up...
The inductor should be between the cap and the driver or the amp will se a DC short - right!?
We're talking about distortion, and the frequency response, as commonly measured, is not enough to reveal these phenomena, I'm afraid.If the electrical impedance of a driver was modulated, it's frequency response would also be modulated, changed.
It's certainly as interesting topic and thanks for all the ideas. I guess we seldom think of a loudspeaker in reverse, i.e. as a microphone, although it must be happening all the time. Maybe it's just negligible in the end, I don't know. It would seem to me that horns with compression drivers would be the most sensitive.
- I think if this was real, the acoustic nonlinear distortion (whatever its form) measured with steady signal would depend on the room location at which the source was placed. Does this happen?
The very first measurement of my A520G2 I took a while ago, just to check everything is up and running.
It's the small 1" Peerless with the T520-25-STD-1 adapter:
The task now is find another available 1" driver that would perform like this. Any candidates?
And a quick ~0/10/20/30 deg set:
Shouldn't require a lot of EQ 🙂
BTW, A460G2 has been released.
A520G2 + SB ROSSO-65CDN-T
I was a little bit nervous but this is fine 🙂
- Acoustic Horn Design – The Easy Way (Ath4)
