DHT Headphone amp for HifiMan Edition XS
SSHV2 is CCS feed shunt (FET) stabilizer.
Do you use separated stabilizers for each channel?
In #155 post the B+ values was different.
If independent SSHV2 serves each channels, at 45mA anode current the SSHV2 CCS must be set to 55mA.
The 45mA (15R filbias, 0.65A filament) is valid, if B+ is 190V.
It will cause a problem.
If the one channel 4P1L anode current is 45mA and the VAS tube is #26 with 5.5mA anode current, with other low currents the power consumption over 51mA.
Two channels consumes 102mA.
The SSHV2 CCS high voltage FET usually DN2540 or IXTP1N100.
The former very sensitive to spikes, I lost many of them. Not recommended here.
The last one can't do that current.
You must rebuilds SSHV2 CCS part with higher current capacity depletion MOSFET, for example IXTP08N100D2.
Yes.
The Rset value of SSHV2 CCS about 6R for 122mA.
Larger heatsink is required for SSHV2, the total dissipation about 7.5W (if raw HT supply is 220V).
Reactions: merlin el mago
