SB Acoustics 3 way active build - Advice
no doubt good advice in a general sense.
In this particular situation, @neo004 is using Hypex FA amps. I have used 8 to 10 dB 2nd order shelf to boost woofer output with my Hypex FA253 amps. The hardware/software of these amps seem unfazed by big EQ over 0 dB.
They use a adau1452, which has 42dB of headroom.
But don't forget the DAC, preamp etc as well.
I forget if they have their buffers running at 15V or 18V rail, but that gives you about 24dB or 25dB of headroom, referenced to a 1Vrms signal.
Those Hypex amps have a gain of around 20x (18.8 to be precise).
So we need at least 1Vrms to be able to deliver 100W@4ohm
The Hypex has multiple input options, analog balanced (XLR), analog single ended (RCA), digital SPDIF (coax), and digital AES. I only use the RCA analog connection. I imagine that this might be much more forgiving of operating above 0 dBFS than the other inputs, or maybe not.... So just be aware that my experience is only valid with analog RCA inputs.
Reactions: Juhazi
So for @neo004, keep this all in mind. I doubt the hypex HFD software would let us build a filter which pushed the Hypex DSP over its limits. But it might be better for you to start conservatively, especially if you are using something other than RCA inputs.
When you build the filters in HFD, you can always adjust the overall gain, or the gain of the individual drivers, down so that the max gain on the woofer is at 0 dB.
j.
I don't doubt that, I have done it.
Well okay that was just with a separate adau1452 into a ncore module
I don't know if they changed something in their own firmware to prevent these kinds of things.
They do have a "clip indicator" pin onboard, so I assume they use that.
But that is just an assumption, I am not that familiair with their software, rather prefer SigmaStudio (understatement)
They do have some circuitry to prevent bad things from happening, but can't completely recall the schematic anymore.
Btw, this is not just a "Hypex problem" but always be something to lookout for even if you use other components.
This is always a trade-off between more gain in the power stage, but also adding more noise because of that gain.
Hi Fredygump,
Thanks for the info.
I guess what i'm hoping for is a high end set of floor standers, Using good quality proven drivers and a good quality amp. From there it's up to me to dial in crossovers etc and learn along the way. I have built a CNC router so i'm looking forward to making the cabinets myself.
I have looked at spending $4k on a set of retail floor standers but then i think i would enjoy building something, something a bit out of the normal and learn a lot in the process.
The aim for the speakers is to cover the full spectrum if i'm listening in stereo for music. Or to blend in with an 18" full marty sub and a couple of 15" devastator type subs. These aren't built yet, in the planning at the moment also.
Size wise isn't too much of a problem, there is plenty of room. Any normal/large floor stander size will be fine.
I'd like them to play reasonably loud for movie watching, but im not sure what DB that would relate to.
Will be active crossovers, Hypex
Thanks all
I was just looking at the SEAS KingRO4Y Mk III Active Loudspeaker Kit.
Seas mentioned you could increase the size of the cabinet to a floor stander and then add in a passive woofer to match the subwoofer driver.
That seems to hit your mark. $3,700 or so you supply the cabinet, and passive radiator (optional) (YMMV based on options)
Two tips for taking measurements.
1. Don't put pillows / soft furnishings on the floor in an attempt to absorb or reduce reflections. You want hard surfaces! This makes it easy to spot the first reflection ripple. Basically with gated responses, you want as many hard surfaces as possible in your listening environment, so you can spot the first early reflection easier therefore set the gate with confidence. Little ripples in your response (especially below ~ 1KHz) are indicative of a reflection sneaking into your response (gate set too long)
2. Put your mic on a long boom. I used a piece of "PVC repair pipe" of a suitable diameter for your microphone. It was already split in two halves. I got from Mitre10 / Bunnings The clip / stand most people use will cause high frequency ripple in the response. You want your boom length > distance from mic tip to speaker (i.e. keep the stand out of the "sphere of measurement"). Here's mine:
Reactions: stv
Re DSP - if your source is playing at a 0dB / 100% level, then I would avoid any + EQ or gain in DSP. Everything should be minus to avoid clipping.
I use software DSP and harvest clip warnings from logs to see if this has occurred. I've never had a problem when using the above approach. Assuming you have low noise floor DAC and amplifiers, additional gain needed to offset the minus approach should not lead to audibly increased noise.
Hi guys,
Glued on the front baffle yesterday so gave the front a quick sand. Loooots more sanding to do on the sides etc due to using bulk glue to make sure it sealed properly lol.
A few pics attached, they are monsters. I could just lift them without the drivers in them.
I'm going to start playing with the Hypex crossovers, I'll add that Highpass/PEQ, whichever you think is better, what frequency am I aiming at for that?
Edit - Just done a quick in room rew measurement, 1m on axis with tweeter. Currently all 4th order to get me started, 1600hz & 200hz.
3db cut on the tweeter, 5db boost on the 12".
Green plot has 3db shelf boost on the 12" at 30hz just experimenting.
Hi guys,
Looking very good 👍
But - could you try and do a gated measurement at 0, 10, 25 - until 90 degrees, in the horizontal plane, so that we can see exactly what is going on in the crossover region of the midrange and tweeter?
I am very late to this discussion but I have some experience with the plate amp FA 123 having recently completed a center channel with it. Here's my thoughts;
  • Use a smaller 4-5" midrange. This will let you push the tweeter crossover to 3 kHz, improving the tweeter's dynamic range considerably.
  • The Hypex FA123 has the same max power rating regardless of speaker impedance (8 vs. 4) so might as well stick with 8 Ohm drivers, which will have a higher minimum
  • Hypex e-mail support is excellent. The unit I received had the wrong firmware and thought it was a 2-way.
Hi all,
Project is still active, Currently the speakers are at the painters getting 2pak painted. Going with white for something different, should be a nice contrast to the black drivers.
They have been at the painters for about a month now, they are just slipping it in between jobs, for beer money, so I can't complain lol.
I will have lots of testing to do once i get them back, the only problem is, is that I basically can't lift them with the drivers in, they are damn heavy.
So i'll have to work out the best way to get my testing done.
Sorry, I meant to say that from the photos it looked like your shape was rounded more than what I've seen in other baffles where just the edges were rounded.
If you've seen Soundblab's YT videos he has a couple of speakers where they are cut on a table saw.
Thx
Ahh ok I see.
Yeah the idea of that was basically to fix the same problem. I tried to get the roundover to start right up near the tweeter.
So for a bit of a feature, i did a variable roundover along the whole length of the speaker, so it sort of looks symmetrical.
Normally people might use a huge roundover/router bit, but I have a CNC router, so i could make it whatever i wanted.
