Yet another ESL57 rebuild
Some photos on the new refurbished with dark handcrafted spiderlegs.
Reactions: Mistercontach
I have refurbished som older EHT-units and quite happy with the result. My EHT boards are sealed with a layer of plastic before attached to transformer.
Here is a set of audio transformers restored with new resistors and upgraded to handle more than 15W power as later standard. Those Erie resistors getting high resistance values. fore example a 180K resistor is measures over 220K and I decided to replace them all. Also the weak banana jacks where replaced with some high quality German manufactured ones (no need for drilling). Protection units for the treble panels will start clipping over 2,2KVolt. Original Erine caps used when possible.
Reactions: Bill Brown and 2tec
The spacing between your diodes and the mounting screws on your clamp boards is pretty small, you might have arcing from the diode legs to that grounded mounting screw. You might want to conformally coat the board or switch to plastic fasteners (not sure plastic sheet metal screws exist though).
IPC-2221 covers spacing for high voltage circuits if you are interested: https://resources.altium.com/p/using-an-ipc-2221-calculator-for-high-voltage-design
Sheldon
Is there anyone having an opinion about applying coating on one or both sides of the panels? I have opened several and what I think i see is coating on one side by Quad themselves. But I have read some claiming it needed on both sides?
With coating on both sides of the Mylar the force is weaker than when applied only to one side. So it looks like they work against each other or at least have interference that does not help. Why, I don't know, but it surely does.
And most important, distortion levels are higher, which also might indicate the two coated sides having some interference.
