I replaced them with unpolarized caps a while ago. Measure the bridge and get some unpolarized replacements 47uF 25V
The swap meet forum is for private non-commercial transactions. Only unmoderated members can post here.
Swopping polarity will work as well. Swopped the polarity around on the boards I bought from you. And then there is 8 volt accross them with negative probe on negative pole and positive probe on positive pole.I replaced them with unpolarized caps a while ago. Measure the bridge and get some unpolarized replacements 47uF 25V
So the IRF840 is doing fine in this circuit? I have also purchased them for this board.I found the fault.
I found out that the experiment cables that I use between the trafo and the 6,3v module are to thin that I get a voltage drop.
I took another pair and paralleled and I now get 6,3v dc out.
The rectifier is SB560.
Will change to unpolarized.But it still working as it is.I think they are a part of a voltage doubler.c1 and c2 are the wrong way around still. Check my post 87 and 88.
