NAP-140 Clone Amp Kit on eBay
in addition to Oleg who makes excellent PCBs, there was also a guy who made great boards, he passed by here but I don't remember his name, it's something like "kawoei" or a stuff like that.
I have one of these pcbs somewhere to rebuild my nait5.
@Oleg Turbin, does that mean anything to you?
I have the original board from Nait5i-2
Also i have DIY boards Nait2 and Nait3
You have the Nait5 or Nait5i ?
Also have the DIY boards for NAP140 olive
All diy boards make in fabric from original design
Nait5i-2
У меня есть платы NAP140 без деталей
Если Вам нужен комплект с деталями у меня его на продажу нет.
Оригинальные детали дороги и в данный момент их трудно достать.
Hello,
Interesting question, i am interested too....i found much different plans/schematics in the I-Net . On the most Nap 140 schematics the 10 or 15 Ohm resistor is missing, the coil/inductor too. Instead there is a 0,22 Ohm resistor in the output, as in the Nap 180 clone too. Only the schematics of the Nap 250 has the 15 ohm resistor with 1 µh inductor ? I think its very similar to an 0,22 Ohm resistor. Chinese informations about their boards are not helpful. No idea what i have built....a little bit of everything...Nap 250? I have to test it....
Greetings
Peter
Hello Oleg,
do you know about the differences at the output ? In some case i can find a boucherot network with 1 µH inductor and 15 Ohm resistor, in an other case exspecially on china clones an 0,22 ohm resistor after the zobel network. Is it perhaps only a mod ? In my oppinion the boucherot network is the better way for critical impedances.
Peter
U can use the inductor on the output paralleled with 10R 3W resistor and use any speaker cable you like or prefer.
You do not need to mount the mentioned items on your PCB, it is fine if you mounted on the speakers terminal.
thats all true. If you want to use any cable, you have to use that LR filter. thats for capacitance load due to cable or speaker. It's normal value of this resistor is 10ohms. Some amplificators can use down to 1 ohm. I want to know that how decided to use that unusual 15ohm value. Is this experimental result? if so what is the capacitance of the load( >2uf)?
