Maximize a Scanspeak 18M/4631 T00 Revelator midrange for a 3 way
Midrange appears to be a well behaved unit. On its own high passed at 140 Hz LR4, 4 litres sealed, well damped to Qtc=0.74, without any other consideration, it can be fed with 20Vrms of input and not exceed 2mm of cone travel.
I would have tested it with both HF drivers. Crossing to d2905 conservatively at about 2.3-2.5 kHz.
So I've made a few cabinets......And I'm always overcomplicating things, when all I should be doing is a quick simple box.
SS M18 mid box is now 6.2 liters net with quite a lot of filling. ( can fill it up with MDF to best volyme)
Did the first measurements and Impedace shows FS at 106 Hz? (brand new driver)
You skilled people, what does this look like?
Regards John
Hi Jawen,
I see a Low frequency roll off around 120Hz due to box size and stuffing. A little blip in impedance around 160 and 250Hz. Maybe more stuffing would take care of them?
Diffraction loss of approx. 6dB spread over 400-900 Hz.
Consequently if you intended to use it from 400Hz you will have to deal with that which suggest to me that your your efficiency if you adjust for the loss will be around 82-83dB for the test input level you used.
Reactions: jawen
The frequency response has a lot of room influence. Try a nearfield measurement and gated 0,5m distance measurement.
But the problem is the impedance measurement! There should not be dips at 150 and 250Hz! Is this really from the speaker or some humm/whatever?
Reactions: jawen
I agree, there's something not right at 140 ish and 230 ish hz. Could be standing waves at measuring height and distance or the enclosure may have small air leaks. I've seen incorrect applications of dampening material do that as well.
Reactions: jawen
This is without 1/48 smooting
Having problems with REW settings to mesaure impedance, never remember the settings between times Grrrrrr
Dont get it to work now when i try to do a new impedance mesaure
This looks like 50Hz hum and harmonics. Ground loop or interference - you need a tidier setup to get rid of these.
Do you also find the 900Hz peak of the datasheet?
The rest looks good.
